60
[GUIDE] OnePlus 5: How to Unlock Bootloader | Flash TWRP | Root | Nandroid & EFS Backup and More !!
  1. AlexandreP
    Honeycomb Dec 13, 2017
    AlexandreP , Dec 13, 2017 :
    Hi!
    Please be aware that OxygenOS 4.5.15 is still based on Android 7.1.1 Nougat.
    If you want to upgrade your system to the latest stable 4.5.15 build and keep root, you will have to
    (0) reboot into recovery,
    (1) flash the full OTA package through the recovery,
    (2) flash your favorite root software -- be it Magisk or SuperSu --,
    (3) wipe dalvik and cache, and only then
    (4) reboot to the system.
    Make sure you have the flashable ZIP for your rooting solution beforehand somewhere in the internal storage of your phone. As for the system update, your should have received the full OTA package (as it is bigger that 1 GB), and it will be located in the .Ota folder of your internal storage.
    Oreo will only come with OxygenOS 5.x series, which currently is only released as Open Beta 1 (and beta software will not be OTA-pushed through the System updates above a stable version). If you want to test the Oreo OxygenOS Open Beta 1 for the OnePlus 5, your would read OxygenOS Open Beta 1 (Android O) for the OnePlus 5
    ringen00 likes this.
  2. ringen00
    Cupcake Dec 13, 2017
  3. ringen00
    Cupcake Dec 14, 2017
    ringen00 , Dec 14, 2017 :
    This is strange: Now as I found the time to update to 4.5.15 it's not offered anymore!
  4. ringen00
  5. ringen00
    strange but now I can download it'
  6. goku6666
    Froyo Dec 23, 2017
    goku6666 , Dec 23, 2017 :
    I have installed Oreo beta 2 and have problem with root. I stuck on flash TWRP. When go to TWRP Go to Mount --> Select Storage my all storage have 0 MB. How to fix it?
  7. O1514267739958
    Cupcake Dec 26, 2017
    O1514267739958 , Dec 26, 2017 :
    I have sucesssfuly roted my OnePlus.
    Now there is new system update that I need to install. AS I could understand the root will be lost after that.
    What do I need to do to get the root access back after system update ?
  8. ringen00
    Cupcake Dec 27, 2017
    ringen00 , Dec 27, 2017 :
    How can I install Oxygen OS 5 (offered via ota) without losing data and root?
    Please help me and give me instructions!
  9. AlexandreP
    Honeycomb Dec 27, 2017
    AlexandreP , Dec 27, 2017 :
    Hi! -- Just make sure to flash your preferred rooting solution (Magisk, SuperSU...) after applying the full system update if you're going from 4.5.x to a newer revision of 4.5.x (i.e. 4.5.14 to 4.5.15).
  10. ringen00
    Cupcake Dec 28, 2017
    ringen00 , Dec 28, 2017 :
    Someone in the telegram group advised me to reset my phone (after flashing the latest twrp) and then restoring from Titanium (custom apps)...
    I'm a bit confused now.
  11. ringen00
  12. AlexandreP
    Honeycomb Dec 29, 2017
    AlexandreP , Dec 29, 2017 :
    Yeah, I've read a bit more about that on XDA, and it certainly does not look like a walk in a park for rooted guys... :) Note that I'm on the same boat as you are (stock OOS 4.5.15, encrypted, rooted, with TWRP), so I'm interested on the subject.
    Not sure to understand everything. If I read correctly, if we're to flash the full ROM (and we would have to, because we are rooted) and we reverted to stock recovery for the time of upgrade, then we're in no luck -- a factory reset is required at the end on installation.
    An upgrade -- using full ROM -- through a compatible TWRP seem doable without losing internal storage... but only if we're decrypted. That's not my case, probably not yours either.
    ... Still doing some reading before attempting an upgrade. ;)
  13. Adem2660
    Cupcake Jan 4, 2018
    Adem2660 , Jan 4, 2018 :
    [Help needed - stuck at installing SuperSU]
    I'm on OxygenOS Open Beta 3 Root Oneplus 5.
    However, in TWRP, it says 0 MB internal storage and I cannot locate any files - not even SuperSU. Therefore I cannot root my phone. What do I do? I followed all steps (I'm a software developer, so I'm not really a noob in following steps).
    I do have the .zip on my internal storage, but my TWRP says 0 MB and it cannot locate the file. Actually all I see is a bunch of folders but with no data at all.
    [Fixed] Apprently the TWRP didn't work for my updated phone. Take alook at this if you're on Android 8 (Oreo) http://www.droidviews.com/install-twrp-root-oneplus-5-android-8-0-oreo/
  14. ringen00
    Cupcake Jan 5, 2018
    ringen00 , Jan 5, 2018 :
    How can I update to Oxygen 5.0.1 ?
    I'm decrypted (no_verity) and actually on Oxygen 5.0 .
    It says that if my boot loader is unlocked that the update would probably fail...
  15. ringen00
    Cupcake Jan 15, 2018
    ringen00 , Jan 15, 2018 :
    it randomly happens that I can't open the notification panel (swipe down doesn't work) OOS 5.0.1, Nova, Cerberus. Anyone Experteninterviews the same?
  16. MartinStenqvistG
    Eclair Jan 22, 2018
    MartinStenqvistG , Jan 22, 2018 :
    Is there any way to relock the bootloader after you have installed magisk without wiping the phone? I just wanna get rid of the message on bootup that says bootloader is unlocked.
    Anyone understand what I mean?
  17. AlexandreP
    Honeycomb Jan 29, 2018
    AlexandreP , Jan 29, 2018 :
    Not sure you will be able to do so, as installing Magisk tempers with the boot image. If you succeeds in relocking your bootloader, you most certaintly encounter a lesser-pleasant warning message that can prevent your device from booting.
  18. SimplySaggu
    Cupcake Feb 6, 2018
    SimplySaggu , Feb 6, 2018 :
    Hello!
    TWRP not showing internal storage, not even asking for password/pattern for decryption. :(
    Please help.
  19. xAn0nYm3x
    Froyo Feb 9, 2018
    xAn0nYm3x , Feb 9, 2018 :
    Same problem for me.. i've try to update TWRP but no change...
    [EDIT:] I found the problem ! I think you are using the wrong recovery.. the cheesburger one don't work with the last OP update. Try following this link : https://forum.xda-developers.com/oneplus-5/how-to/official-oxygenos-4-5-2-7-1-1-ota-t3627003 it was good for me :) have a good day :) your french friend :D
  20. adescartesio
    Cupcake Feb 11, 2018
    adescartesio , Feb 11, 2018 :
    Oem is already unlocked!
    I can flash twrp, but it stay on my phone until i reboot. Next reboot recovery i found default recovery. With default i can see magisk.zip but flashing fail every time!
    Ok, i reflash twrp and try to browse between file (i use twrp since i rooted my galaxy S3) but i can able to find magisk.zip. "data" partition cannot be mounted because "invalid argument".
    Could you help me?
