43
[GUIDE] OnePlus 5: How to Unlock Bootloader | Flash TWRP | Root | Nandroid & EFS Backup and More !!
  1. ZENTAC69 Cupcake Jun 26, 2017
    ZENTAC69, Jun 26, 2017 :
    Hello
    i have root my O+5 with TWRP 3.1.1.0 SuperSu 2.82 and OTA 4.5.2
    but then i have NO access from the apps to the "SD-Card" memory!
    and if i make a Picture the Camera it will be not Save the Pictures and Say "No Pictures"
    Did i have forget a step at the rooting procedure??
    or have the OTA 4.5.2 a Problem?
    i have no idea....
    installation of my APPs are not ok too, some Apps cant not be installed from GooglePlay Example TOMTOM
    Someone have solve this Problem?
    Thanks
    Z.
    #61
  2. El_pelosss Cupcake Jun 26, 2017
    El_pelosss, Jun 26, 2017 :
    enters in twrp.Luego go to advanced and to terminal .. and he writes this
    restorecon -FR /data/media/
    and restart
    #62
    ivivdim likes this.
  3. ZENTAC69 Cupcake Jun 26, 2017
    Hello
    thanks for your fast answer,....
    it looks better but i think its better to reinstall it all new....
    whats the right install chain???
    Root and TWRP are installed.....
    better i
    1. delete Dalvik DATA SYSTEM and Memory every thing,.....
    2. Transfer OTA + SuperSU + DM Verity Zip
    3. reboot directly to TWRP
    4. Terminal restorecon -FR /data/media/
    5. Install OTA 4.5.2 + wipe Cache/Dalvik
    6. Install SuperSU + Wipe Cache/Dalvik
    7. Install DM Verity Zip
    8 Reboot to System?
    can this be the right way that the 1+5 will be work "normaly"?
    this things makes me crazy... :-(
    Thanks for a Small information
    Best Regards
    Z.
    #63
  4. collin5022 Gingerbread Jun 26, 2017
    collin5022, Jun 26, 2017 :
    Can somebody please explain to me why you would possibly want to disable encryption on your device after unlocking the bootloader and rooting? What is the true purpose of flashing "no-verity-opt-encrypt"? #confused
    #64
    jadecolour likes this.
  5. Funk Wizard Lollipop Moderator Jun 26, 2017
    Funk Wizard, Jun 26, 2017 :
    Ignore if you dont want to decrypt and use multirom
    #65
    Peshyy likes this.
  6. yudaiboin Cupcake Jun 26, 2017
    yudaiboin, Jun 26, 2017 :
    Im already stuck at the commandprompt not showing my device at 'fastboot devices' , really have no idea what I am doing wrong.I installed the drivers multiple times
    #66
  7. Amogh25 Cupcake Jun 27, 2017
    Amogh25, Jun 27, 2017 :
    HI , could anyone please explain in detail what am i supposed to do when there is a partial update OTA?
    #67
  8. 1+T4me Gingerbread Jun 27, 2017
    #68
  9. TreatnHerRight Honeycomb Jun 27, 2017
    TreatnHerRight, Jun 27, 2017 :
    And just finished this! Posting from my OP5 now. For the EFS backup is doing it from TWRP nandroid okay too?
    #69
  10. Marucins Eclair Jun 27, 2017
    Marucins, Jun 27, 2017 :
    1. Root for OnePlus 5: "SuperSU" or"Magisk Beta" - what better to choose?
    2. Just starting with Android, I have a question about Decrypt Data (Flash DM Verity Zip) what advantage or disadvantage gives me this option?
    #70
  11. TreatnHerRight Honeycomb Jun 27, 2017
    Based on previous replies it seems you would want to Decrypt data if you want to use MULTIROM. If you do not want to use MULTIROM, then ignore that.
    #71
  12. F_Ron_Poppe_WtRF Ice Cream Sandwich Jun 28, 2017
    F_Ron_Poppe_WtRF, Jun 28, 2017 :
    choice is yours, both do the same at the base core. if you wish to use android pay go magisk beta to hide superuser from android pay (same with other apps such as pokemon go), magisk also has a module addon for adblocking that i like
    #72
  13. ivivdim Gingerbread Jun 28, 2017
    ivivdim, Jun 28, 2017 :
    [QUOTE="..............................
    Let me make it clear once you are rooted, you have to flash the full zip to upgrade the OS, OTA flash will fail as we have made modifications to the system partition.[/QUOTE]
    Tell me if i only Unlock Bootloader, but nothing else (no custom recovery and root) will i be able to use the "standard" OTA updates like before?
    #73
  14. Marucins Eclair Jun 28, 2017
    Marucins, Jun 28, 2017 :
    How to update phone correctly?
    I have an unlocked phone, loaded TWRP, made Root by Magisk.
    There is a message that awaits update 4.5.3.
    I've already downloaded 4.5.3 on the phone (OnePlus5Oxygen_23_OTA_008_all_1706262145_3301f08afa9145a6.zip)
    What's next?
    //edit
    1. DL new FW version (1,58GB) + Magisk (zip)
    2. Run Revovery TWRP
    3. Install FW + Magisk
    4. Clean Dalvik & Cache
    #74
  15. papolytic Gingerbread Jun 28, 2017
    papolytic, Jun 28, 2017 :
    The most critical component of all these posts above is TWRP. Neither the Chinese nor the XDA provided TWRP are past "work-in-progress" states. Bluntly, they don't function correctly. Until TWRP can nandroid backup and restore any of the boot/data/etc partitions, and reboot without problem, it's only of use for installing things. For some of us, that's a dodgy notion if you can't restore to ground 0 without a problem.
    I might be something fairly simple that's not been accounted for like SELINUX permissions or perhaps restoring while in "permissive mode" rather than in "enforcing mode". With a nice device like the OP5, I'd as soon wait until this most basic of components (custom recovery) has reached a completed state until changing from stock. I'm guessing this will take another week or (well, whatever it takes).
    Of course there are many who don't care whether they can restore their backups because they haven't had to yet, but they'll care as soon as they have to.
    When I see so many posts that say things like "How to install or update phone correctly", well there's no "correct" way until TWRP has reached a not only stable but working under all conditions state, which of course means // the ability to restore all partitions without errors and reboot them.
    I'm not saying there's not useful stuff in this thread, because it's full of useful stuff. All it lacks is a really solid/functioning version of TWRP. I realize that we all want to jump on this cool 'geek/dev' phone and mod the hell out of it and no one wants to fill it with personalized data before unlocking which will wipe data thus causing more work to re-do steps.
    Just think of how much time you'll waste trying to restore your base copy from nandroid since that functionality isn't working. ..
    #75
    jadecolour and G_EVR like this.
  16. _DEDSEC_ Jelly Bean Jun 29, 2017
    _DEDSEC_, Jun 29, 2017 :
    Home
    OnePlus
    How to unlock Bootloader, Install TWRP and Root OnePlus 5
    By
    Ajinkya
    Last Updated: Jun 28, 2017 at 20:06
    OnePlus’s latest flagship offering, OnePlus 5 is simply “enough”, anyone would ask for in an Android Smartphone. With 8GB of RAM & Snapdragon 835, it has really got no competition left in the market. While the Smartphone is the fastest among Galaxy S8 & HTC U11, it surely comes with more than just “Speed”. As we all know, OnePlus always encourages new developments for their devices and allow their users to Root their device without voiding the warranty.
    If you’re one of those, who loves to tinker with their devices & you have recently bought a brand new OnePlus 5, we have a good news for you; A fully functional TWRP Recovery & Root is out for OnePlus 5. While rooting the OnePlus 5 won’t be for “Performance improvements”, but it will surely allow you to install Custom ROMs, apply themes, try out the latest Android O previews and that too without voiding device’s warranty. So without anymore time, let’s just jump onto the procedure of Rooting OnePlus 5.
    Also Read:
    Prerequisites:
    1. A OnePlus 5 with at least 50% of battery
    2. Original Type-C USB Cable of OnePlus 5.
    3. Minimal ADB Tool (Download link and Installation Procedure is given in the link) & Fastboot Drivers.
    4. Backup all your Contacts, Apps, Images and everything. Unlocking the device might erase the Internal storage.
    5. TeamWin Recovery Project (TWRP): Download
    6. Disabled Forced Encryption (no-verity-opt-encrypt): Download
    7. SuperSU Root File: Download
    Table of Contents [Hide]
    Rooting Procedure of OnePlus 5
    How to Root OnePlus 5
    1. Unlocking Bootloader: Opens the door to System files of your device. This allows you to flash images onto the main system partitions of the phone.
    2. Installing a Custom Recovery: A custom recovery is flashed onto the recovery partition of the device and overwrites the stock recovery that exists by default. Custom recoveries bring lots of functionality and allows you to perform wipes, install flashable zips, create full backups of your NAND (Nandroid backup), and various other features. An unlocked bootloader is needed to install a custom recovery.
    3. Rooting: You can gain root by either flashing via recovery a pre-rooted custom ROM, or flashing a zip containing the SuperSU binaries. A custom recovery is necessary to do this. You can unroot your Android device in just one click.
    How to unlock Bootloader on OnePlus 5
    How to unlock the Bootloader on OnePlus 5
    Step 1. Setup the Minimal ADB Fastboot Tool mentioned above.
    Step 2. Enable Developer Options: Go to Settings > About Phone > Tap on Build No. 7 Times > It will say “You’re now a Developer”.
    Step 3. Enable OEM Unlock: Go to Settings > Developer Options > OEM Unlock > Toggle to Allow bootloader unlocking.
    Enable OEM Unlocking in Android
    Step 4. Open Minimal ADB Folder and launch “command.bat” file to open a Command Prompt window.
    Step 5. Boot OnePlus 5 into Fastboot Mode: Press volume + power button and then phone will boot into fastboot interface.
    Step 6. Connect your OnePlus 5 with PC/Laptop using a Type-C USB Cable.
    Step 7. Type the below command to check if everything is working properly: (It will display the list of devices connected)
    • adb devices
    Step 8. Enter the below command to unlock the Bootloader on your OnePlus 5:
    • fastboot oem unlock
    Step 9. Now you’ll see an “Unlock Bootloader” prompt, press Vol button to Select & Power button to select the “Yes” option.
    You have successfully unlocked the Bootloader of your OnePlus 5 device. Now you can install custom Softwares in to your System files through custom recovery or gain root Access.
    How to install TWRP Recovery on OnePlus 5
    Install TWRP in OnePlus 5
    Step 1. Download the TWRP img file from the Prerequisites section at the top.
    Step 2. Place the downloaded TWRP image file inside the ADB Folder.
    Android Debug Bridge (ADB)
    Step 3. Boot your device into Fastboot Mode (Press volume + power button) and connect your device to PC through USB cable.
    Step 4. Launch the ADB Command Prompt Window and type the below command to flash the TWRP img file.
    • fastboot flash recovery twrp-3.1.1-0-oneplus5.img
    • If you have changed the File name, replace "twrp-3.1.1-0-oneplus5.img" with that "filename.img" in the command.
    Step 5. Once the TWRP Recovery is flashed successfully, disconnect your device and boot into TWRP mode (Power + Volume Down button).
    You have successfully flashed TWRP Recovery in your OnePlus 5. But you need to disable Forced Encryption to gain Root Access.
    Disable Forced Encryption in OnePlus 5
    Just like every other Flagship devices this days, OnePlus also comes with dm-verity check and forced encryption enabled. Although this offers a layer of Security, it doesn’t allow you to gain root access. Along with that, encryption also eats up Performance & Storage for keys. If you want to gain root access, first you need to disable forced encryption before flashing anything through TWRP. It’s a pretty simple step.
    Step 1. Download the “no-verity-opt-encrypt” file from the Prerequisites section and transfer it in your device’s Internal storage.
    Step 2. Turn off your device and boot into TWRP Recovery(Power + Volume Down button).
    Step 3. Select Install > Locate the no-verity-opt-encrypt file > Swipe right to Confirm Flashing.
    How to Root OnePlus 5 through SuperSU
    Flashing SuperSU and dmverify to root OnePlus 3T
    Step 1. Download the SuperSU zip from Prerequisites section and transfer it in your device’s Internal Storage.
    Step 3. Select Install > Locate the SuperSU Zip file > Swipe right to Confirm Flashing.
    Step 4. Wait for the Flashing procedure to complete. Once it’s completed, restart your device into System.
    Finally you have rooted your OnePlus 5 device completely and now you can tinker with various options, Custom ROMs, themes, Rooted Apps and lot more. If you have any doubt regarding any steps, you can comment it below.
    Ajinkya
    https://devs-lab.com
    He loves to experiment with Tech and express his views about it. He has been into Media reporting & blogging for five years. If you don’t find him at the office, he is probably out for a bike ride.
    #76
    lostLambda and JuliusZet like this.
  17. F_Ron_Poppe_WtRF Ice Cream Sandwich Jun 29, 2017
    F_Ron_Poppe_WtRF, Jun 29, 2017 :
    and how do you think they get that functionality? testing, yes that's right... we jump on the 'geek/dev' and we test and report issues, submit logs. All this so people who complain can complain about something else... or if it doesn't get done complain they don't have it.
    might be why this post was made in the development section of the forums.
    #77
  18. Racetouareg Cupcake Jun 30, 2017
    Racetouareg, Jun 30, 2017 :
    Hello,
    it's not possible for me to flash recovery twrp-3.1.1-0-oneplus5.img:
    sending 'recovery' (25932 KB)...
    FAILED (remote: Requested download size is more than max allowed
    finished. total time: 0.001s
    Can someone help me?
    #78
  19. G_Jo_Jo_oAdY Gingerbread Jun 30, 2017
    G_Jo_Jo_oAdY, Jun 30, 2017 :
    Hi,
    Nothing spécial for twrp, but after shutdown the OP5 there is a very long time for startup and have the luncher.
    Someones have the same ?
    #79
  20. FatherStorm Froyo Jul 1, 2017
    FatherStorm, Jul 1, 2017 :
    #80
