43
[GUIDE] OnePlus 5: How to Unlock Bootloader | Flash TWRP | Root | Nandroid & EFS Backup and More !!
  1. ivivdim Gingerbread Jul 1, 2017
    ivivdim, Jul 1, 2017 :
    I think that this post have to be put in the beginning of the thread!
    Thank you for this information!
    #81
  2. Joth135 Gingerbread Jul 1, 2017
    Joth135, Jul 1, 2017 :
    try checking your bootloader is unlocked, in fastboot wipe/format recovery -
    commands: fastboot wipe recovery
    or fastboot format recovery (can't remember if you can format recovery)
    then try reflashing TWRP
    or if you just want to use TWRP once just type fastboot boot TWRP.img
    #82
  3. Joth135 Gingerbread Jul 1, 2017
    good alternative to supersu is magisk v13 beta build works with Android pay
    #83
  4. bombalicious Froyo Jul 1, 2017
    bombalicious, Jul 1, 2017 :
    I updated my OP5 via OTA, now I lost TWRP and root. Is this normal? Do I have to flash it TWRP and Magisk again via ADB?
    #84
  5. Funk Wizard Lollipop Moderator Jul 1, 2017
    Funk Wizard, Jul 1, 2017 :
    Whenever you flash OTA Full Zip for update flash Magisk after that else TWRP would be replaced by Stock Recovery
    You can flash TWRP from Fastboot and then flash Magisk from TWRP
    #85
    1+T4me and bombalicious like this.
  6. bombalicious Froyo Jul 1, 2017
    #86
  7. Simping Cupcake Jul 1, 2017
    #87
  8. Funk Wizard Lollipop Moderator Jul 1, 2017
    #88
  9. Saif_786 Froyo Jul 2, 2017
    Saif_786, Jul 2, 2017 :
    I had a small question.
    Once I have unlocked bootloader & rooted my device, I won't be able to install OTAs. I need to flash the complete OTA zip (1.5GB+) correct?
    If I wish to install the OTA updates directly (small size) what do I need to do?
    #89
  10. Marucins Eclair Jul 2, 2017
    Marucins, Jul 2, 2017 :
    Yes.
    If you already have TWRP then the updates you make from the full package (1,58....+ GB) not from the differences OTA.
    #90
  11. Saif_786 Froyo Jul 2, 2017
    What do I need to roll back the changes and start the OTA?
    #91
  12. G_唐佳鑫_ReYK Cupcake Jul 3, 2017
    G_唐佳鑫_ReYK, Jul 3, 2017 :
    Why is your keyboard looking cool? Can you tell me how to do it? @Funk Wizard
    #92
  13. Funk Wizard Lollipop Moderator Jul 3, 2017
    Funk Wizard, Jul 3, 2017 :
    I use Gboard, you have the option to set any image as it's background
    #93
    pinto123 likes this.
  14. G_唐佳鑫_ReYK Cupcake Jul 3, 2017
    ok,thanks
    #94
  15. G_唐佳鑫_ReYK Cupcake Jul 3, 2017
    Can you pass me the hd? I think it's pretty cool.@Funk Wizard
    #95
  16. G_唐佳鑫_ReYK Cupcake Jul 3, 2017
    #96
  17. Funk Wizard Lollipop Moderator Jul 3, 2017
    Pass what ?
    #97
  18. G_唐佳鑫_ReYK Cupcake Jul 3, 2017
    #98
  19. Funk Wizard Lollipop Moderator Jul 3, 2017
    #99
  20. G_Rami_Mustikkamaa_Xkcu Cupcake Jul 3, 2017
