47
[GUIDE] OxygenOS - How to Unlock bootloader, Install Custom Recovery & Flash the OxygenOS.
  1. FamouzUniquee
    Jelly Bean May 14, 2015
    FamouzUniquee , May 14, 2015 :
    @Hemanth.Tiyyagura make sure you go to developer settings and UNCHECK/UNTICK mark the "Update Cyanogen Recovery" !!
    #81
  2. cheechjuan
    Donut May 14, 2015
    cheechjuan , May 14, 2015 :
    Ive just installed OxygenOS and when i insert a usb cable the one shows charging but it shows in both the computer and the one that there is no usb cable connected. (settings>storage>3 vertical dots>USB computer connection--> says Connect your device to a computer to access USB connection settings.) Here is what i have found....
    1) Its the same cable ive always used
    2) connecting my one to another computer with that cable and same results
    3) connection another one to my computer with the cable works fine
    4) connecting another one to another computer with cable works fine
    5) I can reboot the one in fast boot with "fastboot reboot" via Command Prompt
    6) I can adb push files to it as well
    Please if anyone has had this issue or knows how to fix it PLEASE let me know. Im slamming my head on my desk right now.
    #82
  3. cyrusli
    Eclair May 21, 2015
    cyrusli , May 21, 2015 :
    ^ This helped! Thanks!
    #83
  4. chand007
    Cupcake May 27, 2015
    #84
  5. nexxoz
    #85
  6. WolfpackN64
    Jelly Bean May 27, 2015
    WolfpackN64 , May 27, 2015 :
    I think it's worth it. Unless you really use everything CM has to offer, I find Oxygen quite good.
    #86
  7. nexxoz
    Cupcake May 29, 2015
    #87
  8. DK_Gowda
    Cupcake Sep 24, 2015
    DK_Gowda , Sep 24, 2015 :
    Is there any updated zip for oneplus one other than Oxygen 1.0.0..??
    IF SO
    Do v get OTA updates for this OXYGEN 1.0.0 version????..
    #88
  9. Lolster_
    Cupcake Jan 15, 2017
    #89
  10. axbrandao
    Gingerbread Jan 15, 2017
