13
[GUIDE] STOCK CM12S Installation (FASTBOOT)
  1. rizified
    Gingerbread Apr 14, 2015
    rizified , Apr 14, 2015 :
    Pre-requisites - Drivers Installed,ADB,Fastboot.
    Download - cm-12.0-YNG1TAS0YL-bacon-signed-fastboot
    Download - user_data(64gb variant) (also you can use cm11s one if you have it place it inside the extracted fastboot files)
    -Reboot your device into Fastboot Mode (power + volume up).
    -connect your phone to your PC via usb cable.
    -Unzip the file you downloaded and put its contents into your fastboot folder (the same folder that you have adb.exe and fastboot.exe located in on your PC).
    -Open CMD in that folder (Shift+Right click and open new cmd window here)
    -first check the device by entering this command
    Code:
    fastboot devices
    - Enter these commands one by one
    Code:
    fastboot flash modem NON-HLOS.bin
    Code:
    fastboot flash recovery recovery.img
    Code:
    fastboot flash sbl1 sbl1.mbn
    Code:
    fastboot flash dbi sdi.mbn
    Code:
    fastboot flash rpm rpm.mbn
    Code:
    fastboot flash aboot emmc_appsboot.mbn
    Code:
    fastboot flash tz tz.mbn
    Code:
    fastboot flash LOGO logo.bin
    Code:
    fastboot flash oppostanvbk static_nvbk.bin
    Code:
    fastboot flash boot boot.img
    Code:
    fastboot flash cache cache.img
    Code:
    fastboot flash system system.img
    Code:
    fastboot flash userdata userdata_64G.img
    or fastboot flash userdata userdata.img if you have the 16gb model)
    P.S This Userdata will wipe ur internal storage you can skip it if you want.
    Credits - timmaaa
  2. adityakiran1295
    Eclair Apr 14, 2015
    adityakiran1295 , Apr 14, 2015 :
    So I read that after we root the phone, the phones name MIGHT change to bacon or one. And then we won't get an OTA for that. I've root my phone using the bacontool root kit. Not sure if my phones name has been changed :( will I still get an OTA
  3. moogle95
    Donut Apr 14, 2015
  4. azarzar
    Eclair Apr 15, 2015
  5. Paardekam
    Eclair May 27, 2015
    Paardekam , May 27, 2015 :
    Pfew thanks man. My device got useless earlier today (I did not pay attention to the old TWRP version that was on the device). I tried some other guides but got stuck at different moments, but fortunately yout guide worked just fine for me.
    rizified likes this.
  6. Jonsnow6099
    Jelly Bean May 27, 2015
    Jonsnow6099 , May 27, 2015 :
    Very nice guide bro.... Keep it up
  7. Dawn Sangma
    Cupcake May 27, 2015
    Dawn Sangma , May 27, 2015 :
    Hi Could you help me with my problem please.
    Ever since I've updated to CM12 the names of my contacts don't appear when they send me a message only their numbers do. I've gone to themes and changed it to system and to hexo also. But the problem still persists. Thanks.
  8. markpeter
    markpeter , May 27, 2015 :
    Hi, I cant flash system img (error message: sending system FAILED remote data too large)
    can anyone help to resolve this issue?
  9. Mahir08
    Ice Cream Sandwich May 28, 2015
    Mahir08 , May 28, 2015 :
    @timmaaa Hi can you please confirm this below command will function same on CM1144S,05Q etc..
    because i wan't to do fastboot flash without wiping internal storage... :)
  10. kaviraja
    Cupcake Jun 21, 2015
  11. bzyg7b
    Cupcake Aug 2, 2015
  12. aldrinkenneth
    Cupcake Aug 19, 2015
  13. rahul1984
    Donut Aug 21, 2015
  14. blackscorpio
    Froyo Sep 11, 2015
  15. hlidskjalf
    Cupcake Sep 19, 2015
  16. irfan9712
    Cupcake Sep 27, 2015
    irfan9712 , Sep 27, 2015 :
    help! I updated my phone thru recovery mode now it is stuck in booting for 30 mis!
  17. ufuigi
    Gingerbread Oct 23, 2015
    ufuigi , Oct 23, 2015 :
    fkin' love you!
  18. aleb91
    Gingerbread Oct 28, 2015
  19. gersa
    Froyo Jan 13, 2016
    gersa , Jan 13, 2016 :
    Sorry, the file you have requested does not exist.​
  20. ashuashi
    Cupcake Mar 1, 2016
    ashuashi , Mar 1, 2016 :
    The file is not available. Can you post a new link pls
