261
[GUIDE/TEMP FIX] How to Enable New Settings and Temporary Fixes After OOS 5.0
  1. Cosmos_NT
    Jelly Bean Nov 28, 2017
    Cosmos_NT , Nov 28, 2017 :
    then RightNow only thing you can do is to report OnePlus for this as it's a major problem they will surely fix this
  2. F_Andrea_Molin_zzue
    Cupcake Nov 28, 2017
    F_Andrea_Molin_zzue , Nov 28, 2017 :
    i still have so much problem with battery. i can not do more than 2.30 h of screen during the day. any solutions? i've already done what you told me. i think i have wakelocks but i dont know how to solve them... thank you
  3. Cosmos_NT
    take screenshot of that and attach it here
  4. F_Andrea_Molin_zzue
    thanks for the answer! here are the screenshots. i do not have root. if you don't understand italian just tell me
  5. Cosmos_NT
    Attivo - means Awake ...
    this looks to me like you are either getting messages and the screen wakes up or there is something other than standby and screen which is pretty active and is draining battery
    you see mine ? it's just worse than yours because I was using the device whole time it's considerable but your ( either you were using just for watching time or something else for a second or it was receiving notifications that keep it waking up ) is bad in terms of standby
    check which apps are having Background consumption... because if those EDITs didn't worked then there might be something on your device which is consuming it
  6. Krystanos
    Eclair Nov 28, 2017
    Krystanos , Nov 28, 2017 :
    Nice thread. However, the dial code for mobile standby battery drain does not work for me. The phone app crashes...
    Wallace likes this.
  7. Cosmos_NT
    it should work and the app should not crash... do Clear cache from recovery and check
  8. F_Andrea_Molin_zzue
    thank you very much! Do you suggest any apps to download for understand which are the apps that drain my battery life so fast?
  9. Cosmos_NT
    generally I don't use.. I prefer this
    it's calculated by OS so it's best but if you still wish then try AccuBattery from play store, it's free and will show which app consumes more power but it may have ads so be careful of that
  10. F_Andrea_Molin_zzue
    okay i'll let you know how it will go! thank you again and have a good day
    Cosmos_NT likes this.
  11. F_Andrea_Molin_zzue
    As you can see what drain mostly my battery life is android system, standby screen and screen. i don't have apps influence so much the battery life..
  12. Cosmos_NT
    well this is what OnePlus needs to fix... the things I mentioned are working for more than 75 % and it's not for rest so it's a major issue
    I am still experimenting with my battery over Backups and all if I found another temporary fix I'll again add it over main thread
    F_Andrea_Molin_zzue likes this.
  13. Cosmos_NT
    @SoniaB can you edit this as thread title name : [GUIDE/TEMP FIX] How to Enable New Settings and Temporary Fixes After OOS 5.0
  14. SoniaB
    Nougat Senior Moderator Nov 28, 2017
    SoniaB , Nov 28, 2017 :
    Done ;)
  15. Cosmos_NT
    thanks since I realized that it was no longer just guide but also solution over some issue and so someone can search easily
  16. a.594
    Donut Nov 28, 2017
  17. Krystanos
    Eclair Nov 28, 2017
    Cleared cache from recovery, but the app is still crashing...
    I think I'm good for yet another hard reset... This time I'll go for unlocking/rooting, since OTA are so prone to issues leading to hard reset... At least I'll have Daydream ! :)
  18. rmsop3t
    Donut Nov 28, 2017
    rmsop3t , Nov 28, 2017 :
    What is a YouTube red account???
  19. mahafuzhossain13
    Donut Nov 28, 2017
    mahafuzhossain13 , Nov 28, 2017 :
    it's a subscription for YouTube it's like Netflix.
    bro there's another way, you can download this app ogyoutube it's a loophole for YouTube red download the apk and the plug-in.
    rmsop3t likes this.
  20. rmsop3t
    Donut Nov 28, 2017
    I'm not able to wipe any app cache after updating to 2.2.0 launcher. Do I have to uninstall it and get back to 2.1.6 version?
