261
[GUIDE/TEMP FIX] How to Enable New Settings and Temporary Fixes After OOS 5.0
  1. Cosmos_NT
    Jelly Bean Nov 28, 2017
    Cosmos_NT , Nov 28, 2017 :
    different apps have nothing to do with launcher you can go-to settings and do that
  2. Amarjeet Sahoo
    Gingerbread Nov 28, 2017
  3. C1511581797210
    Cupcake Nov 28, 2017
  4. Teknulpe
    Teknulpe , Nov 28, 2017 :
    I have a 1+ 3T. I like a clean HomeScreen - I do not want any App icons on my HomeScreen. I installed the latest update this week and now I cannot find any way to delete App icons that are automatically loaded onto my HomeScreen when I install a new App. I was able delete App icons from the HomeScreen before I installed the update - now I cannot delete them.
    Can anyone tell me how to delete App icons from the HomeScreen now? (Launcher version 2.1.6)
  5. Cosmos_NT
    Jelly Bean Nov 29, 2017
    Cosmos_NT , Nov 29, 2017 :
    long press icon and click remove
  6. G_Lucas_Campero_wNGs
    Donut Nov 29, 2017
    Cosmos_NT likes this.
  7. sagarsewkani
    Eclair Nov 29, 2017
  8. Cosmos_NT
    you know signing in with third-party is risky in terms of stealing data from your device when you provide the apps those permission ?
    it's good to have such app but when you do care for your data it's not good
  9. dennytriwijaya
    Cupcake Nov 29, 2017
    dennytriwijaya , Nov 29, 2017 :
    After updating to Oreo, my oneplus 3 can not receive any SMS.
    The messages app can not be opened and keep crashing, it says "messages keeps stopping".
    I tried download android messages from playstore, now i can send SMS, but still can't receive any SMS.
    Does anybody have solutions?
    Thank you very much
  10. mks123
    mks123 , Nov 29, 2017 :
    Hi,
    I am in the process of installing Oreo Update for my ple plus 3. After down;loading te file, it restarted and is now struck with a message 'Updating please wait'...it has been like this for the last 2 hours. No progress. Please suggest what should be done. Thanks
  11. sagarsewkani
    Eclair Nov 29, 2017
    sagarsewkani , Nov 29, 2017 :
    Yes, what you can do is create another account and subscribe to same people, so your main account isn't at risk.
    and turn off all the permissions for both the apps.
  12. Kapilbhola
    Donut Nov 29, 2017
    Kapilbhola , Nov 29, 2017 :
    bu
    buddy, how about oneplus laboratory ? is it working fine with power control notifications?
  13. luigidn
    Eclair Nov 29, 2017
    luigidn , Nov 29, 2017 :
    Man you saved my battery with fix n. 2!
    Let's pin this post in the forum, it can help to solve many of the ongoing problems on the OOS5.0 update!
  14. piatruss
    Eclair Nov 29, 2017
    piatruss , Nov 29, 2017 :
    Are you referring to changing network from auto to LTE/WDCMA?
    luigidn likes this.
  15. JesRes
    JesRes , Nov 29, 2017 :
    EDIT 2 : For Standby Battery Drain
    Dial *#*#4636#*#* and this will open testing now goto :
    Phone Infromation > Set Preferred Network Type > Now set it to LTE/WCDMA
    Changing from your preferred network to LTE/WCDMA and then you need to wait for the next discharge cycle you will notice the difference.
    NOTE :If you Reboot then you will again required to do the whole procedure since it gets back to original state.
    Hello
    I have this problem ... battery is running out very quickly ... except if I do this step, copied above.
    Any idea when will this be somehow "repaired" ? ... it's annoying to have to go through these steps after every reboot! ...
    Regards!
  16. G_sreevathsa_br_crSI
  17. ramananani
    Donut Nov 29, 2017
    ramananani , Nov 29, 2017 :
    same problem bro ..if open youtube in chrome its directly going to YouTube app then it is not working as chrome in pip
    rmsop3t likes this.
  18. rmsop3t
    Donut Nov 29, 2017
    rmsop3t , Nov 29, 2017 :
    Same problem here!
  19. F_Deepan_Banerjee_emUi
  20. ramananani
    Donut Nov 29, 2017
    please give any suggestion i want YouTube in chrome as pip
