261
[GUIDE/TEMP FIX] How to Enable New Settings and Temporary Fixes After OOS 5.0
  1. Cosmos_NT
    Jelly Bean Nov 29, 2017
    Cosmos_NT , Nov 29, 2017 :
    read main thread
  2. Cosmos_NT
    I have clearly written in thread title that this fixes are Temporary OnePlus needs to fix this
  3. ramananani
    Donut Nov 29, 2017
  4. Cosmos_NT
    read post #1 ( no 1) the whole big written thing in first page
    Blue-agila likes this.
  5. G_Joseph_Eees
    Cupcake Nov 29, 2017
    G_Joseph_Eees , Nov 29, 2017 :
    After oreo update phone cannot receive SMS. Tried wipe cache, did not solve the problem.
    Also cannot connect phone to mac.
  6. Cosmos_NT
    temporary use Google messenger I am trying to figure by searching and it's going to take some more time
  7. G_Joseph_Eees
    Thanks sir. I have tried a lot of sms apps. But still cannot receive SMS.
    Anyway i will have to wait for oneplus to solve this.. Don't want to factory reset.
  8. Cosmos_NT
    first I am not sir I am just a College student and and try clearing cache from recovery
    you can access it by About Phone > 7 time tap build number > go back and click developer options > Advance reboot > press power button and select reboot > recovery and English > wipe data and cache> wipe cache > reboot
  9. G_Joseph_Eees
    Yep. That was the first thing i did after noticing SMS issue. Sadly still persistent.
    My stock sms app also wont open and keeps prompting "messages has stopped working" everytime i try to open.
    Hopefully oneplus can solve. My phone was smooth since i bought it. Just this oreo thing brought chaos. Tsk one plus.
  10. luigidn
    Eclair Nov 29, 2017
    luigidn , Nov 29, 2017 :
    Yes, it works greatly!
  11. italyanoboy13
    Eclair Nov 29, 2017
    italyanoboy13 , Nov 29, 2017 :
    havent checked to be honest but camera problem is back so i'm considering going back yo noogat till Bugs are fixed
  12. ShaiGliner
  13. sagarsewkani
    Eclair Nov 29, 2017
    sagarsewkani , Nov 29, 2017 :
    you'll get it on apk mirror, search Oneplus.
  14. ShaiGliner
    ShaiGliner , Nov 29, 2017 :
    Dont understand.
    I want disable the apk i downlowad for old version its possible?
  15. dennytriwijaya
    Cupcake Nov 30, 2017
    dennytriwijaya , Nov 30, 2017 :
    I had the same problem yesterday, then i reset to factory setting.
    The SMS is normal again.
    Be sure to back up before you do it
  16. G_Joseph_Eees
    G_Joseph_Eees , Nov 30, 2017 :
    What happens when i factory reset. Everything? Photos music videos?
  17. dennytriwijaya
    Just factory reset the system data. Do not erase internal storage. Do not select the erase internal storage option in the below
    Be sure to backup your data before doing it, including backup from apps like WhatsApp, etc, just to be sure.
    After reset it will take a while for the phone to restore all your apps.
    And also you will need to arrange the app again in your home screen,
    G_Joseph_Eees likes this.
  18. poorboy119
    Gingerbread Nov 30, 2017
  19. susanomalis
    susanomalis , Nov 30, 2017 :
    No I'm not! You just need to long press the settings button on status bar and it will give you access to the oneplus laboratory options. However the modification on oneplus lab is no longer available for oreo updates though, bummer
    poorboy119 likes this.
  20. poorboy119
    poorboy119 , Nov 30, 2017 :
    I saw and tried, no luck though! Thanks for the reply
