261
[GUIDE/TEMP FIX] How to Enable New Settings and Temporary Fixes After OOS 5.0
  1. Arai
    Honeycomb Dec 5, 2017
    Arai , Dec 5, 2017 :
    It can't be blocked. At most it can only be put into lower priority, which will display it as a single line at the bottom, without showing the icon in the collapsed notification bar.
  2. Neo13
    Froyo Dec 5, 2017
    Neo13 , Dec 5, 2017 :
    Download and install hide "running in the background" notification app from the playstore.
    G_VISHAL_GOHIL_Uafw likes this.
  3. sandy_cm
    Gingerbread Dec 5, 2017
    sandy_cm , Dec 5, 2017 :
    Go to settings - >apps click on three dot menu select system apps then go to android system->notifications select apps running in background click on importance and select low
  4. G_abdulrahman_alammari_K
    Daniele Sorge likes this.
  5. leo98918
    Ice Cream Sandwich Dec 5, 2017
    leo98918 , Dec 5, 2017 :
    Sorry, I got your comment confused, thinking you were the OP. I thought you wanted to know of a way AND your friend told you about an app.
    You just know there's an app but have no interest in hiding the notification.
  6. G_abdulrahman_alammari_K
    G_abdulrahman_alammari_K , Dec 5, 2017 :
    no problem bro.. and sorry for my bad English, it's not my native language.
  7. Cosmos_NT
    Jelly Bean Dec 5, 2017
    Cosmos_NT , Dec 5, 2017 :
    https://forums.oneplus.net/threads/guide-how-to-enable-new-settings-after-oos-5-0.691637/
    indeed read this temporary fix and other than that....
    search bar is good for everyone...use it and don't create redundant threads
    thread will be closed soon
  8. G_VISHAL_GOHIL_Uafw
    Donut Dec 5, 2017
    G_VISHAL_GOHIL_Uafw , Dec 5, 2017 :
    It's a headache. I couldn't do much. That's why I posted here.
  9. G_VISHAL_GOHIL_Uafw
    Donut Dec 5, 2017
  10. G_VISHAL_GOHIL_Uafw
    Donut Dec 5, 2017
    Cosmos_NT likes this.
  11. G_VISHAL_GOHIL_Uafw
    Donut Dec 5, 2017
    App is even more better than the temporary fix. Temporary fix is not that much helpful.
  12. kunal.h222
    KitKat Dec 6, 2017
  13. Cosmos_NT
    Jelly Bean Dec 7, 2017
    Cosmos_NT , Dec 7, 2017 :
    has a glitch in landscape mode ... you can't see Pro mode and Panorama but still you can press them if you do it carefully... but if you select pro mode before rotating device you can easily do that
    and from 2.0.0 the white balance isn't working and it's still not working ( I guess because the basic version of camera for 3/3T is still kept to 1.5 it was never updated and this are extracted from beta)
    otherwise everything is fine and working well
    kunal.h222 likes this.
  14. Cosmos_NT
  15. G_Narsi_Reddy_efEX
    Eclair Dec 7, 2017
    G_Narsi_Reddy_efEX , Dec 7, 2017 :
    i have updated 3t to oreo in November. sometimes i am facing no response screen with screen touch, at that time if i press lock button twice means again touch becomes responsive. kindly fix this bug.
    Kapilbhola likes this.
  16. Cosmos_NT
    Jelly Bean Dec 8, 2017
    Cosmos_NT , Dec 8, 2017 :
    did you cleared cache after system update? if not then goto Recovery and clear cache
  17. TheAllMaker
    Cupcake Jan 13, 2018
  18. TheAllMaker
  19. Cosmos_NT
    Jelly Bean Feb 10, 2018
