261
[GUIDE/TEMP FIX] How to Enable New Settings and Temporary Fixes After OOS 5.0
  1. Android450
    Marshmallow Nov 26, 2017
    Sun90, italyanoboy13 and GopalB. like this.
  2. GopalB.
    Nougat Nov 26, 2017
    Cosmos_NT likes this.
  3. Cosmos_NT
    Jelly Bean Nov 26, 2017
    Cosmos_NT , Nov 26, 2017 :
    telling me ?
  4. Android450
    Android450 , Nov 26, 2017 :
    Yup go to apk mirror so you can update the link in thread :)
    Sun90 and italyanoboy13 like this.
  5. Cosmos_NT
    oh well I'll do but I don't think I can keep that updation Track for long time
  6. Android450
    It's only recently that they've started updating the camera so much. I don't think you'll have to change it very often later down the line
    Sun90 likes this.
  7. Cosmos_NT
    ya I know... I'll update the link soon
    Android450 likes this.
  8. abhinavmalik
    Cupcake Nov 26, 2017
    abhinavmalik , Nov 26, 2017 :
    Hii , can you also help fixing the contacts issue please. lot of op3 owners are unable to search the contacts. one has to alphabetically search them. very inconvenient it is.
  9. Cosmos_NT
    links of apps are now updated !
  10. abhinavmalik
  11. Cosmos_NT
    What is happening with contact app when you search ? if possible please post a screen shot it will help more
  12. Raghu2706
    Honeycomb Nov 26, 2017
    Raghu2706 , Nov 26, 2017 :
    Thanks a lot buddy for the details on new features. it's very helpful for everyone here in the community. Really appreciate it.
  13. abhinavmalik
    see i have lot of contacts in my contact list starting with 'adv' (image 1) but when i try to search.. see wat turns up (image 2)
  14. Cosmos_NT
    Strange as i tried to search mine it is working perfact for T9 dial pad and keybard search both.
    Have you tried T9 dial pad search ?
    EDIT : Try restarting device and check
    abhinavmalik likes this.
  15. abhinavmalik
  16. Cosmos_NT
    good to know..I'll update the main thread with this problem's solution too
    Themurtuza likes this.
  17. SahilQureshi
    SahilQureshi , Nov 26, 2017 :
    One more question. Should I tick advanced optimisation on or off?
  18. neochri
    Eclair Nov 26, 2017
    neochri , Nov 26, 2017 :
    Mobile standby is draining so much battery. Is there any problem. How i can fix. Thanks
    #38
  19. sagarsewkani
    Eclair Nov 26, 2017
    sagarsewkani , Nov 26, 2017 :
    Check Edit 2 of the post.
    #39
  20. Cosmos_NT
    I am not sure will that option does effect over app background data or not...
    This may stop app from receiving messages or may be I am wrong for that but I have to check that first
    #40
