7
GUIDE TO ROOT ONEPLUS 6/6T [APRIL 2021]
  1. NalydB
    Cupcake Feb 2, 2021
    NalydB , Feb 2, 2021 :
    Did you flash Magisk using TWRP? But you did not install TWRP?
    I'm asking because I wanna root with Magisk but I don't want to install TWRP.
  2. Muhitpias
    Donut Feb 2, 2021
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 2, 2021
    Caomhin , via OnePlus 6T , Feb 2, 2021 :
    Magisk is constantly being updated to ensure use of the various apps that may be affected by rooting a phone. Shouldn't be an issue once you get used to working with Magisk if you are rooted.
    To find out more about Magisk, I would suggest reading the info on it at XDA. It would explain a lot more than I can here.
    You also have modules for Magisk as well. Again you would get more info on them on XDA. The Sticky threads at the first link below will give you a lot of information.
    XDA Magisk Info
    https://forum.xda-developers.com/f/magisk.5903/
    How To install Magisk
    https://www.xda-developers.com/how-to-install-magisk/?amp
    Magisk Manager info.
    https://www.xda-developers.com/install-magisk-manager-without-separate-zip/amp/
    Latest Magisk v21.2 and Magisk Manager v8.0.4
    https://www.xda-developers.com/magi...0-4-released-bug-stability-fixes-root-access/
    Also read the following for Custom Roms.
    How to (maybe) bypass SafetyNet hardware attestation on devices with an unlocked bootloader
    https://www.xda-developers.com/bypa...ttestation-unlocked-bootloader-magisk-module/
  4. F1615430999141
    Cupcake Mar 11, 2021
    F1615430999141 , Mar 11, 2021 :
    after i did the twrp and magisk flash, i can not get out of twrp, when i reboot system, it goes back to twrp. Please help.
  5. Nishant_Surte
    Eclair Apr 12, 2021
    Nishant_Surte , Apr 12, 2021 :
    nope, not really
  6. Nishant_Surte
    Eclair Apr 12, 2021
    Yes, a clean install is always preferred. Dirty flash may cause issues, but it is up to you.
  7. D1613614151137
    Cupcake May 18, 2021
    D1613614151137 , May 18, 2021 :
    Hi. Thanks for this guide.
    I'm using exclusively Mac and Linux and they can work perfectly fine for this process, as adb and fastboot are easier to install than in Wind*ws (it spared me the hassle of finding and installing the drivers).
    So I think it's not accurate to say one needs exclusively Wind*ws PC for this process. Instead, it would be fairer to say "any machine with working adb and fastboot".
    Sorry, just trying to help making the post better.
    Thank you.
    Nishant_Surte likes this.
  8. X1621544224703
    Cupcake May 20, 2021
    X1621544224703 , May 20, 2021 :
    I dont get the serial number but the phone does show up in device manager however it says it doesnt have drivers while in fastboot mode and shows up as "android device" i have had this problem on multiple tutorials and followed every step carfully
  9. Tee_Eee_Bee
    Ice Cream Sandwich May 21, 2021
    Caoimhín likes this.
  10. Nishant_Surte
    Eclair May 21, 2021
    Nishant_Surte , May 21, 2021 :
    I haven't faced any problems as of now, been many months since I have a rooted device.
  11. quaddropop
    Honeycomb May 26, 2021
  12. Caomhin
    OnePlus 9 Series Expert Community Expert May 26, 2021
    Caomhin , via OnePlus 9 Pro , May 26, 2021 :
    If you root the phone but stay with OOS, OTA will no longer work. You will then to download a full install file of the version you are updating to. You may want to check the OnePlus 6 section of XDA to learn more about how to use, update, and what you can do with a rooted phone.
    rhyd1am likes this.
