56
Handling Theme Notification
  1. itsFreelancer
    Honeycomb Feb 3, 2020
    itsFreelancer , Feb 3, 2020 :
    so I just got this as soon as I updated to 10.3.1
    I went to settings. chose all the three themes one by one and finally settled on nuanced dark. now it no longer appears
    #41
    Caomhin likes this.
  2. Panos1988
    Gingerbread Feb 4, 2020
    Panos1988 , via OnePlus 6T , Feb 4, 2020 :
    Same issue here.Tried all the above mentioned solutions but nothing worked.Sad thing is,that since it's a system notification,it can't be disabled.Well it's not a bug that messes up your phone,but still kinda frustrating to see it every time a theme operation action is performed.
    #42
    Ryu_Hayabusa_Listing and Afaaron like this.
  3. Mattimp
    Cupcake Feb 4, 2020
    #43
  4. Kytharsis
    Nougat Feb 4, 2020
    Kytharsis , Feb 4, 2020 :
    Already been answered.
    #44
    Caomhin likes this.
  5. Ryu_Hayabusa_Listing , via OnePlus 6 , Feb 4, 2020 :
    same... the solutions doesnt work
    #45
  6. Chazy
    Cupcake Feb 4, 2020
    Chazy , Feb 4, 2020 :
    Over the handling notification, does someone noticed that, after the update to 10.3.1, you can't answer to the Instagram stories?! Or you can write dm, but you can't see what you're writing?! So, Instagram don't scroll up while the keyboard come in.
    I think it's correlated.
    #46
  7. Caomhin
    KitKat Feb 4, 2020
    Caomhin , via OnePlus 6T , Feb 4, 2020 :
    Already answered on in 10.3.1 thread, no need to Hjack another thread when this has no bearing on it.
    #47
    Kytharsis likes this.
  8. Elivelton Alves
    Cupcake Feb 7, 2020
    #48
  9. Kytharsis
    Nougat Feb 7, 2020
    Kytharsis , Feb 7, 2020 :
    "Looking for incomplete downloads"?
    #49
    Caomhin likes this.
  10. Elivelton Alves
    Cupcake Feb 7, 2020
    #50
  11. Elivelton Alves
    Cupcake Feb 7, 2020
    #51
  12. Kytharsis
    Nougat Feb 7, 2020
    #52
    Caomhin likes this.
  13. Elivelton Alves
    Cupcake Feb 7, 2020
    #53
  14. a.rejaul.karim
    Donut Feb 8, 2020
    a.rejaul.karim , Feb 8, 2020 :
    Same here.
    Updated to OOS 10.3.1 this morning and since then I'm getting this notification quiet frequently. It stays for like 10 seconds and then disappears.
    Have tried tapping on the notification but nothing happens.
    #54
  15. Caomhin
    KitKat Feb 8, 2020
    Caomhin , via OnePlus 6T , Feb 8, 2020 :
    Has been discussed, and there is no solution until next release of OOS, assuming they fix the code for this issue. See above for more info
    #55
  16. Rahul.G9
    Eclair Feb 8, 2020
    #56
  17. G1581186591078
    Cupcake Feb 8, 2020
    G1581186591078 , Feb 8, 2020 :
    I'm getting the same thing. If I put my phone down I notice that every minute or so I get that handling theme notification and I am also seeing a bunch of bug reports. The only thing that changed was the update. I have not installed any new apps since the update and never had that notification or any bug reports before. The weird random freeze on certain web pages seems to have been fixed since the update though.
    #57
  18. Caomhin
    KitKat Feb 8, 2020
    It mainly only happens with a Playstore update, has no bearing on your use of the phone.
    #58
  19. fishandfly90
    Eclair Feb 11, 2020
    fishandfly90 , via OnePlus 6 , Feb 11, 2020 :
    I don't believe it has been answered. Shure people have made suggestions, but after trying them all the notification still pops up. Mine says around 17 times a day. I tried switching to light and back to nuanced dark. No change.
    #59
  20. manosbochos
    Cupcake Feb 11, 2020
    manosbochos , Feb 11, 2020 :
    Same here after the 10.3.1 update on OP 6t. It happens only when updating apps and at the moment of the notification pop-up the music playing on the background volumes down for a couple of seconds and then back up.
    #60
