56
Handling Theme Notification
  1. IlConte81
    Cupcake Feb 22, 2020
    IlConte81 , Feb 22, 2020 :
    I have the same problem, but also if you change from Dark to White and after a bit back to Dark, it appears again. Seems to be related to the Dark theme itself. Seems also that is draining a bit more the battery. Hopefully will be solved i the next minor update.
    #81
  2. pm_mazur
    Froyo Feb 26, 2020
    pm_mazur , via OnePlus 6T , Feb 26, 2020 :
    Turned out it was just a fluke or coincidence. I think the notification appears when there's an app running in the background that uses an auto theme settings based on your systems theme, such as the store
    #82
  3. MvrBhargav
    Cupcake Feb 29, 2020
    MvrBhargav , via OnePlus 6T , Feb 29, 2020 :
    There is an issue with my device after android 10 update which is shown in attached screenshot. This notification is frequently being pop up and I unable to sort out which settings need to changed. Help me if there is any chance to off this notification or how to get out of that.
    #83
  4. Caomhin
    KitKat Feb 29, 2020
    #84
  5. D1583000292338
    #85
    evenfrost likes this.
  6. drl431
    Marshmallow Feb 29, 2020
    drl431 , Feb 29, 2020 :
    This can happen when a mod merges a new, redundant thread, with an existing thread...
    #86
    Caomhin likes this.
  7. tr1234567
    Cupcake Mar 6, 2020
    tr1234567 , Mar 6, 2020 :
    I found the solution Press long on top of the notification go to Settings press silent notification as pictured
    #87
  8. ZFIZE
    Cupcake Mar 16, 2020
    ZFIZE , Mar 16, 2020 :
    I too have the same problem but in my case the apps crash on my op6t after the update.
    I can’t play online cuz the app crashes every time. (It’s not a problem with the app cuz I have reinstalled and cleared cache)
    Same with YouTube too.
    Help
    #88
  9. Caomhin
    KitKat Mar 16, 2020
    Caomhin , via OnePlus 6T , Mar 16, 2020 :
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of Android. So you will need to backup your phone.
    After Backing up the phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
    #89
    drl431 likes this.
  10. #90
  11. Kytharsis
    Nougat Mar 17, 2020
    Kytharsis , Mar 17, 2020 :
    It's not an issue... this is a feature of Android 10.
    #91
    drl431 and Caomhin like this.
  12. #92
  13. Kytharsis
    Nougat Mar 17, 2020
    According to the notification name, it's specific to OP. Still not an issue.
    #93
  14. Great Gatsby , via OnePlus 7 Pro T-Mobile , Mar 17, 2020 :
    so you're telling me that if you were using a phone that didn't do that, and all of sudden a new phone you get starts to notify all the time it's not an issue? c'mon now it becomes an issue when something is ab normal.
    #94
  15. Kytharsis
    Nougat Mar 17, 2020
    Is it intrusive to your daily use? Not really. It only lasts a few seconds, why make a huge deal out of it?
    #95
  16. Great Gatsby , via OnePlus 7 Pro T-Mobile , Mar 17, 2020 :
    that's like saying I bought a new car but it makes a ticking sound. it doesn't affect the day to day use, but it shouldn't make a ticking sound. so it's an issue.
    #96
  17. AndruC
    Donut Mar 20, 2020
    AndruC , Mar 20, 2020 :
    Kytharsis, stop this. You don't get to be the judge as to what is intrusive or not. Changing the theme is NOT a solution to this problem (and yes, it is a problem).
    This notification pops up over a dozen times a day, it provides no useful information, is not under my control. It is not expected or desired behaviour, and it only shows up on a recent version of OxygenOS. Its existence is a bug.
    I like my theme the way it is. Changing it to remove this notification is a ludicrous suggestion.
    Your contribution to this thread has been to tell people over and over that their problem is not a problem and they should either accept it or change their theme. Move along if you're not going to be helpful.
    #97
  18. Caomhin
    KitKat Mar 20, 2020
    Caomhin , via OnePlus 6T , Mar 20, 2020 :
    As mentioned before about this issue, the suggestion below will reduce those notifications until OnePlus change it.
    You can minimise the app notifications, and possibly silence any sound it makes.
    Go to Settings>Apps and notifications>All x apps>3 dot menu>Show system apps>Android System>Notifications|>FG OPThemes...
    Select - Other less important without sound and Vibration.
    Should reduce intrusions.
    #98
    Afaaron, Kytharsis and drl431 like this.
  19. AndruC
    Donut Mar 20, 2020
    Reduction is definitely a start, thank you. I use pushbullet to broadcast my notifications to my pc, so we'll see how well this works.
    #99
    Caomhin likes this.
  20. Andrew32
    Cupcake Mar 28, 2020 at 9:12 PM
    Andrew32 , Mar 28, 2020 at 9:12 PM :
    I've had this for a very long time, just managed to stop it.
    Every day for me at 9pm autou starts, and that's what it's notifying, it's downloading.
    quickly caught it and turned all download notifications off, it's now gone.
    Caomhin likes this.
