HandSet Volume via OnePlus 7T
  1. orhancelen7
    Cupcake Jul 15, 2021
  2. pablofg1978
    Head Moderator Head Moderator Jul 15, 2021
    pablofg1978 , Jul 15, 2021 :
    Hello there,
    I moved your thread to a more appropiate section. Introduce yourself section is not meant for this type of content
  3. orhancelen7
  4. orhancelen7
    Cupcake Oct 28, 2021
  5. JanLuck.Pincard
    Jelly Bean Nov 1, 2021
    JanLuck.Pincard , via OnePlus 7T , Nov 1, 2021 :
    Do you mean volume of a bluetooth handset ??
    Check in settings if absolute volume is on.
    Otherwise phone volume and handset volume react independantly..
    So settings - sound - headphone modus - bluetooth absolute volume.
  6. orhancelen7
    Cupcake Nov 1, 2021
  7. orhancelen7
    Cupcake Nov 1, 2021
  8. JanLuck.Pincard
    Jelly Bean Nov 2, 2021
    JanLuck.Pincard , via OnePlus 7T , Nov 2, 2021 :
    Yes, the front facing speaker. So the downward speaker at the botom is normal and the top speaker has low volume. Since the phone allows stereo sound it might be a incorrect ballance setting but I would not know how to correct that since I have not found a ballance slide in the settings of my 7T.
    Could also be a hardware dammage of the top speaker and occurrence after your last update could be purly a unlucky coincidence
    and I have seen pictures of a extra slide in the mixer called call volume. never seen that one myself, but it might only be there when actualy in a call.
    try opening the mixer ( the slider symbol at the Bottom that appears in the bottom of the popup screen for volume when you are connect in a phonecall.
