Hanging problem via OnePlus 9 Pro
  1. bipaloneplus
    Cupcake Aug 26, 2021
    bipaloneplus , via OnePlus 9 Pro , Aug 26, 2021 :
    I have purchased One plus 9 Pro and i am facing call hanging problem continuously in my new phone which is only 29% storage used.
    Let me know guys if any one of you are facing the same issues.
    Help me in resolving the issue.
  2. Xcommunicad0
    KitKat Aug 27, 2021
    Best Answer
    Xcommunicad0 , via OnePlus 8T , Aug 27, 2021 :
    No, not really. Actually when you try to uninstall it just uninstalls the Updates only and not the App.
    Would suggest to try it, sometime it helps.
    Preferably uninstall the updates, restart your Phone and then re-install the updates.
    bipaloneplus and the_o2 like this.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 26, 2021
    bipaloneplus likes this.
  4. Xcommunicad0
    KitKat Aug 26, 2021
  5. Pinku Reddy
    Gingerbread Aug 26, 2021
  6. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Aug 27, 2021
  7. bipaloneplus
    Cupcake Aug 27, 2021
  8. bipaloneplus
    bipaloneplus , via OnePlus 9 Pro , Aug 27, 2021 :
    Hey i have already cleared the Cache but facing the same problem. For phone calls i think there is no updates and we can't uninstall it.
  9. bipaloneplus
  10. bipaloneplus
    No the network is constant infact i have tried using the new sim and other service provider but facing the same issue.
  11. bipaloneplus
    I have tried this now and have restarted my phone let me check if it still continues.
  12. bipaloneplus
    Thanks brother it worked my problem has been resolved after uninstalling the Updates. Thank You
    Xcommunicad0 and the_o2 like this.
  13. Xcommunicad0
    KitKat Aug 28, 2021
    Xcommunicad0 , via OnePlus 8T , Aug 28, 2021 :
    Great, it worked!!
    Happy to help ☺️
  14. Xcommunicad0
    KitKat Aug 28, 2021
    the_o2 and bipaloneplus like this.
  15. bipaloneplus
    Cupcake Sep 15, 2021 at 6:03 AM
    bipaloneplus , via OnePlus 9 Pro , Sep 15, 2021 at 6:03 AM :
    Bro the solution which you suggested was temporary again after few days i am facing the same problem. I have talked with the customer care guys also they are asking to erase all the data's and than try it. But i think this is not the solution.
  16. Xcommunicad0
    KitKat Sep 15, 2021 at 6:58 AM
    Xcommunicad0 , via OnePlus 8T , Sep 15, 2021 at 6:58 AM :
    Hi, clearing the storage for all the Google apps might help here. Try once again, if possible for all the below and restart & reinstall...
    Google,
    Google Play Store,
    Google Play Services,
    Android System WebView
  17. bipaloneplus
    Cupcake Sep 17, 2021 at 5:40 AM
    bipaloneplus , via OnePlus 9 Pro , Sep 17, 2021 at 5:40 AM :
    I will try this too bro. thank You
