25
[HAPPINESS] Cm12s. A better Camera!
  1. ageorgiou
    Ice Cream Sandwich Feb 13, 2015
  2. whalley1986
    Eclair Feb 13, 2015
    whalley1986 , Feb 13, 2015 :
    Looking forward. The cm11s camera app is a pretty horrible. I mean I have used much worse but looking forward to a better experience.
  3. Robblackburn
    Cupcake Feb 13, 2015
    Robblackburn , Feb 13, 2015 :
    Hooray! I ordered mine on Tuesday despite the camera being pretty important to me and knowing it isn't great on the opo. This gives me hope I won't be dissapointed!
  4. dEramubu
    Eclair Feb 13, 2015
    dEramubu , Feb 13, 2015 :
    I hope they put it in nightlies soon , rather than wait for final build of cm12s
  5. Elderon
  6. FXA
  7. astralbee
    astralbee , Feb 13, 2015 :
    I hear it written a lot that the camera on Color OS is significantly better. I'm no developer, but as I understand it Color OS is built on Android and although it doesn't come with Google Play (that's the point of it, for the China market) it can be installed. So conversely, should not the Color OS camera APK just work on Cyanogen?
  8. delpinsky
    delpinsky , Feb 13, 2015 :
    It's a shame! Shame, shame!
    It's basically one of the coolest features of Lollipop and what do they do? They do not implement it.
  9. osaz_oe
    Honeycomb Feb 13, 2015
    osaz_oe , Feb 13, 2015 :
    Hey peeps, little off topic but any ideas why eleven on cm12 orders album tracks in alphabetical order?
  10. Anant Goel
  11. B4kken
    Lollipop Feb 13, 2015
  12. BigRedBaron
  13. F4TinF1T
    Froyo Feb 13, 2015
    F4TinF1T , Feb 13, 2015 :
    Does OPO get CM12 OTA update or just that oxygenOS update? If OPO wont get CM12 update I'm going to sell my OPO!
  14. TheArowanaDude
  15. delpinsky
    Don't you worry :)
    CM11S to CM12S via OTA
    or
    CM11S to OxigenOS via fastboot
    For sure, if you want to try OxigenOS, they will upload the ROM to flash via fastboot and surely a batch file (.bat) to do all the necessary steps automatically, as they did for the "fix" against bricks.
  16. Bananinha
  17. delpinsky
    @Bananinha
    cm-11.0-XNPH05Q-bacon-signed-fastboot.zip
    Unpack the zip with the ROM where you got the adb files: (i.e. C:\adb\)
    adb.exe
    AdbWinApi.dll
    AdbWinUsbApi.dll
    fastboot.exe
    Factory Reset OnePlus One 64GB (type the commands manually one by one).
    Code:
    fastboot flash modem NON-HLOS.bin
    fastboot flash sbl1 sbl1.mbn
    fastboot flash dbi sdi.mbn
    fastboot flash aboot emmc_appsboot.mbn
    fastboot flash rpm rpm.mbn
    fastboot flash tz tz.mbn
    fastboot flash LOGO logo.bin
    fastboot flash oppostanvbk static_nvbk.bin
    fastboot erase system
    fastboot flash system system.img
    fastboot flash userdata userdata_64G.img
    fastboot erase boot
    fastboot flash boot boot.img
    fastboot erase recovery
    fastboot flash recovery recovery.img
    fastboot erase cache
    fastboot flash cache cache.img
    if you want to lock the bootloader add:
    Code:
    fastboot oem lock
    if you want to keep your Custom Recovery, skip the line erase/flash recovery...
    reboot your phone with this line...
    Code:
    fastboot reboot
    If you want to create a .bat file, add these lines at the beginning of the .bat file:
    Code:
    @echo off
    echo #########  This patch is Created by ONEPLUS Technical Support.  #######
    echo ###### This patch should only be used for ONEPLUS ONE 64GB Global Version. ######
    @echo off
    and the add all the lines about "fastboot" and "erase".
    Original OnePlus fix based on XNPH44S if I'm not wrong:
    We prepared an Automated batch file which will fix your issue automatically, all you need to do is to download the zip file from the link below and extract it, after extracting please open the "README.pdf" and follow the instructions.
    PLEASE NOTE :- IT WILL DELETE ALL YOUR PHONE'S DATA> PLEASE BACK UP YOUR PHONE'S DATA
    https://s3.amazonaws.com/oneplussupport/ONEPLUS ONE-FIX-Windows.zip
    This should resolve your issue. :)
    Regards
    Sanam
  18. Bananinha
    #38
  19. meganoobmind
    meganoobmind , Feb 13, 2015 :
    they said clearly camera2 api will not be at first release. They told clearly first release will be lite version.
    Till then we have CM12s guys :)
    #39
  20. loperaster09
    loperaster09 , Feb 13, 2015 :
    CM12s is really close to release now. Even CMXlog doesn't state what's going to be added in the next nightly... (which never happened before)
    Look Here.
    #40
    zygi10s likes this.
