Having heating issue while charging and also ghost touches
  1. Sahilk0369
    Honeycomb Dec 3, 2018
    Sahilk0369 , Dec 3, 2018 :
    since few days having heating issue where charger and phone gets hot and while charging the phone having ghost touch issues.
  2. GopalB.
    Nougat Dec 3, 2018
    GopalB. , Dec 3, 2018 :
    Looks like something is wrong with the power source...
    Try some other power socket or other places...
    Sahilkum likes this.
  3. Sahilk0369
    GopalB.
    Try some other power socket or other places...​
    I tried at 2/3 different power outlets in different rooms
    sometimes the level of heat and ghost touches varies but still present
    i also tried multi touch tester apps and they also show ghost touches
    getting this issue after I guess 9.0.5 update
    also no issue when the phone is used after removing the charger
  4. GopalB.
    Nougat Dec 3, 2018
    Try some other place, not same house...
  5. Sahilk0369
    I will try that too
    thank you for your suggestion
    I shall report back soon
  6. GANAPATHI SUBRAMANYAM J
    Froyo Dec 3, 2018
    GANAPATHI SUBRAMANYAM J , Dec 3, 2018 :
    seriously bro even I was troubled with ghost touches last night and I rebooted my system and ghost touches were presently gone and even now I opened my community app for complaining about that itself thank God I found a thread. and I need to know why those ghost touches came and will they occur again or not! please help me!
  7. felipemendes
    Jelly Bean Dec 3, 2018
    felipemendes , Dec 3, 2018 :
    See if you can slow charge using a battery instead of the wall. 100% times I had problems with ghost touch was caused by poor charging.
  8. ChrisX0z
    Gingerbread Dec 3, 2018
    ChrisX0z , Dec 3, 2018 :
    Are you using oneplus accessories?
    Do you have AOD enabled?
    There's multiple reasons why your device could be potentially overheating.
    Same as for negative feedback off your digitizer (touch sensor under the glass).
    If you could provide more info for the 1st 2 questions & what kind of apps you have installed.
    Personally alot of overheating comes from apps having background run times that aren't necessary like a malicious app.
    As for ghosting accessories not made by OnePlus can have those effects (screen protector/ case)
  9. GANAPATHI SUBRAMANYAM J
    Froyo Dec 3, 2018
    I am using everything OnePlus accessories itself except the screen protector i bought in different store and downloaded some movies and I think that is the reason ok I hope it doesn't come back again thank you!
  10. ChrisX0z
    Remove the screen protector and orser the Oneplus one if you still think you need it.
    OnePlus did make the statement about using approved screen protectors. It was on the plastic placed on the screen when you took it out of the box.
    As for movies being downloaded i would check your source files & see if additional files were zipped with it.
  11. Sahilk0369
    using the charger and cable that came in the box
    using only apps like snapchat,insta,whatsapp.
    never had any issue with these apps on other oneplus phones
  12. Sahilk0369
    Honeycomb Dec 4, 2018
    Sahilk0369 , Dec 4, 2018 :
    temperatures can reach about 42C while charging without even using the phone.
    I just picked the phone while charging, it felt really warm so downloaded this app to check
  13. GopalB.
    Nougat Dec 4, 2018
    GopalB. , Dec 4, 2018 :
    Ok... But what about the other issue???
  14. Sahilk0369
    GopalB.
    Ok... But what about the other issue???​
    thank you so much for your quick support
    I got the 9.0.7 yesterday and charged the phone for the first time after the update.
    Ghost touches didnt happen just for this instance but heating was present.
    Also the charger seems to be getting quite warm
  15. GopalB.
    Nougat Dec 4, 2018
    Heating can be caused by multiple things...
    Luckily oneplus fast charging don't overheat the phone... But app running in background, Bluetooth scanning, data, GPS, poor reception...
    All these can lead to the device getting hot...
  16. GopalB.
    Nougat Dec 4, 2018
    Fast chargers usually have to change the voltage and current ratings so some step up/down is being performed...
    And that can lead to the charger getting all heated up... It's normal...
    Even the dash charge is build in inside the charger and not the phone... Just to keep the phone cool... And that also adds up some heat in the charger...
  17. Sahilk0369
    totally understand that as I have used other oneplus phones with Dash Charge also.
  18. Sahilk0369
    Honeycomb Dec 6, 2018
    Sahilk0369 , Dec 6, 2018 :
    Been 2-3 days since I got the 9.0.7 update, after that heating issues and ghost touches while charging dont seem to be happening.
