having wifi issue. wifi better on mipad1
  1. F_Jothi_Vanan_KhIO
    Froyo May 8, 2017
    F_Jothi_Vanan_KhIO , May 8, 2017 :
    I use my op3t and mipad 1 nearby. My op3t lose wifi signal easily and shows only weak signal - 1 bar, whereas my mipad shows 2-3 bar and doesn't lose signal. Mipad came 3yrs ago. Op3t months only. Any bug fix?
  2. peaky blinders
    Jelly Bean May 8, 2017
  3. saviods86
    Cupcake May 8, 2017
    saviods86 , May 8, 2017 :
    Since the last 4weeks I've noticed that my WiFi keeps disconnecting and then reconnects after 3-5 seconds. I've read a lot of people are facing this issue, is there a way to solve this? It's very irritating as I can't make Skype calls anymore due to the disruption of WiFi. At first I thought it was my home network issue but I have the same issue at Work and other wifi spots.
  4. ExtremeNuker
    Gingerbread May 8, 2017
  5. F_Jothi_Vanan_KhIO
    Froyo May 8, 2017
  6. Ramdinpuia
    Honeycomb May 8, 2017
    Ramdinpuia , May 8, 2017 :
    Actually my oneplus 3 and oneplus 3T both have stronger reception than my xiomi redmi 4A, oppo F1s (sister of oneplus), galaxy tab 10", and my wife's galaxy J prime.. I had presumed that the modem on the oneplus is pretty good.. Especially as it's all metal
