headphone cable
  1. P1523088595089 Cupcake Jun 7, 2019
  2. parag008 Ice Cream Sandwich Jun 7, 2019
    parag008, Jun 7, 2019 :
    u can buy any type c to 3.5 mm converter out there on market.
    i have bought one from locals shops around, it works fine.
    also u can look up on amazon.
  3. ShreyRatna Eclair Jun 7, 2019
    P1523088595089 likes this.
  4. P1523088595089 Cupcake Jun 7, 2019
  5. P1523088595089 Cupcake Jun 7, 2019
    P1523088595089, Jun 7, 2019 :
    does converter affects the sound quality??
  6. parag008 Ice Cream Sandwich Jun 7, 2019
    as long as i have heard it i dont think so there is any drop in audio quality.
    but at least purchase good cable.
    dont go for cheap ones.
  7. parag008 Ice Cream Sandwich Jun 7, 2019
    this is what i use right now. and it works absolutely fine.
  8. P1523088595089 Cupcake Jun 7, 2019
  9. parag008 Ice Cream Sandwich Jun 7, 2019
  10. thetonyclifton Froyo Jun 7, 2019
    thetonyclifton, Jun 7, 2019 :
    The Apple one didn't work for me at all. I had to buy one another from amazon.
  11. parag008 Ice Cream Sandwich Jun 7, 2019
    thetonyclifton
    The Apple one didn't work for me at all. I had to buy one another from amazon.​
    i meant any by locally available ones
    why would u pay high price when it can work in 100 indian rupees.
  12. asdulla Donut Jun 7, 2019
    asdulla, Jun 7, 2019 :
    yes they do...
  13. asdulla Donut Jun 7, 2019
    alternative is wireless earphones,.. if you have no issues with it.
    otherwise a good adaptor alone will cost more than a good wired earphones/headphones.
    Be_Kind likes this.
  14. parag008 Ice Cream Sandwich Jun 8, 2019
    parag008, Jun 8, 2019 :
    actually they dont if u use passive ones.
    op7 has built in DAC.
  15. thetonyclifton Froyo Jun 8, 2019
    thetonyclifton, Jun 8, 2019 :
    I don't live in India and already had an apple cable. it is also useful information to people that not all cables work with the OP7 pro. I have read reports that the 6T cable doesn't work. Not sure if that is true but it's clear that not every usb-c to 3.5mm converter will work.
  16. parag008 Ice Cream Sandwich Jun 8, 2019
    that is different. normally they should have worked.
    but great since you clarified that not every cable supports. it helps to people to be careful while choosing one.
  17. P1523088595089 Cupcake Jun 9, 2019
    P1523088595089, Jun 9, 2019 :
    one plus must think about it... at least the cable must be in stock..after buying 33k phone everyone talking about headphone cable ...WTF.
  18. raevilman Eclair Jun 9, 2019
    raevilman, Jun 9, 2019 :
    as adapter on OnePlus store is out of stock and most of the options available on e-commerce websites doesn't have good rating or comments.
    can anyone suggest/share product link who is using the adapter ordered online and is working fine in terms of music and calls....?
  19. prfraczek Gingerbread Jun 9, 2019
    prfraczek, Jun 9, 2019 :
    any of these reds
    https://www.google.co.uk/search?q=oneplus usb to 3.5mm adapter&source=lnms&tbm=shop&sa=X&ved=0ahUKEwiPipy3jd3iAhXirHEKHeElAqAQ_AUIECgB&biw=1536&bih=731&dpr=1.25
  20. sudheervenkata Froyo Jun 18, 2019
    sudheervenkata, Jun 18, 2019 :
    I agree
