3
Headphone jack is loose
  1. devb95
    Honeycomb Jan 11, 2019
    devb95 , Jan 11, 2019 :
    Whenever I plug in my headphones in the jack, it comes out with the slightest pull. I don't even hear the earlier snap fit it used to have. What can be the issue?
  2. eye842
    Lollipop Jan 11, 2019
    eye842 , Jan 11, 2019 :
    Dust or pocket fluff might prevent you to get the jack into the snapped position.
    Did you use the headphones somewhere else? a slightly smaller hole can damage the plug so you can't use it again normally, tried that on a airplane once.
    rogermensah and borft like this.
  3. Madnezz4Ever
    Jelly Bean Jan 11, 2019
    Madnezz4Ever , Jan 11, 2019 :
    Theres tiny metal pins inside the port to secure the jack that are more then likely wearing out due to constant headphone use.
    If this is the case, get it fixed or somehow secure the cord to the phone when you use headphones.
  4. N1517575344486
    Cupcake Feb 6, 2019
    N1517575344486 , Feb 6, 2019 :
    I had the same problem, it's just some dust and stuck pocket lint stuck in the earphone jack that is pushing the earphones out.
    Take a safety pin and carefully try to pull out the lint, altho minute..but your earphones will work like a charm post that !
    Hope this helps :)
  5. Y1516905595766
    Cupcake Apr 25, 2019
    T1511372059013 likes this.
  6. Waveform Modifier
    Marshmallow Apr 26, 2019
    Waveform Modifier , Apr 26, 2019 :
    You do realize this is a bit old and you are talking to air, right? If you are going to dig up old threads, at less quote someone in the thread to talk to.
  7. Y1516905595766
    Cupcake Apr 26, 2019
    Y1516905595766 , Apr 26, 2019 :
    Didn't realize that. First time here dude.
  8. Akshay_Nalavade
    Froyo Apr 26, 2019
  9. Y1516905595766
    hey, just clean the jack with something. that'd be enough.
  10. Deactivated User
    Aug 10, 2019
    Deactivated User , Aug 10, 2019 :
    Worked like a charm, remove the dust and it will be like brand new 3.5 mm JACK
    getefix and Anil_Hajari like this.
  11. Anil_Hajari
    Froyo Dec 2, 2019
  12. Waveform Modifier
    Marshmallow Dec 2, 2019
    Waveform Modifier , Dec 2, 2019 :
    Maybe read the thread before posting. That had already been said and provided.
  13. getefix
    Donut Feb 27, 2020
    getefix , Feb 27, 2020 :
    This worked for me too. Used a paper clip to pick it out. Just keep digging and digging and you'll be amazed how much dust and lint comes out. My headphone plug was being pushed out and now it firmly fits into place. Phone is 2.5 years old and works great.
    McJader and Praetax like this.
  14. Praetax
    Cupcake Jan 4, 2021
    Praetax , Jan 4, 2021 :
    I feel like an idiot, it's so obvious. I was about to order a new jack, and take my phone apart, then I came across this thread. Got a pin, and cleared out the dirt, and the Jack is absolutely fine now, thanks for the help guys.
    McJader likes this.
  15. Laxmankumar001
    Cupcake Jun 9, 2021
    Laxmankumar001 , via OnePlus 6 , Jun 9, 2021 :
    Thanks, It worked for me.
    McJader likes this.
  16. #16
  17. Waveform Modifier
    Marshmallow Jun 20, 2021
    Waveform Modifier , Jun 20, 2021 :
    Pretty sure this 2 years old thread had been answered well before you got here.
    Artemus. likes this.
