headphone jack symbol problem.
  1. prvnare
    Cupcake Oct 22, 2017
    prvnare , Oct 22, 2017 :
    Hi ,i am using one plus 5 , now i am facing one issue in mobile when i disconnect the headphones from mobile it is still showing jack symbol and not able to remove it ..i need to restart the mobile..any sollution for this.thanks
  2. G_plusone
    Marshmallow Oct 22, 2017
  3. G_plusone
  4. Senti3nt
    Ice Cream Sandwich Oct 22, 2017
    Senti3nt , Oct 22, 2017 :
    Clean the headphone jack with a moist earbud or anything using alcohol. Also clean the earphone plug. Remember that it should be just little moist with alcohol and clean them. Restart and try.
  5. DhiRu94
    Cupcake Dec 26, 2017
    DhiRu94 , Dec 26, 2017 :
    i am experiencing the same problem from morning.. can you help me if it is working fine for you now..?
    #op5
  6. D1593937386514
    Cupcake Jul 5, 2020
    D1593937386514 , via OnePlus 5T , Jul 5, 2020 :
    I am facing similar issue.
    I tried the below things but in vain
    1. Reboot
    2. Restart after shutting it down for an hour
    3. Cleaning the socket with alcohol moist bud
    4. Plugging the jack in and out
    Is there anything else I can do?
