Heating issue after oreo update
  1. Shubham Adukia Gingerbread Feb 15, 2018
    Shubham Adukia, Feb 15, 2018 :
    Since last oreo update, phone gets warm (sometimes hot) while charging. There was no such issue before the update.
    There are some shinny spots on the back panel of my midnight oneplus 5t. Seems like there is some issue with the Anodised Aluminium. I want people to check there respective phone.
    JulianDeal likes this.
  2. bhaskarrejintala Donut Feb 15, 2018
  3. Shubham Adukia Gingerbread Feb 15, 2018
    bhaskarrejintala
    i too far same issue and heat issue during download of large files more than 500 mb tooo​
    Check your phone's back... is there any shinny spots.
  4. G_Anthony_Waterhouse_Rzp Cupcake Feb 15, 2018
    Fc København likes this.
  5. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 15, 2018
    NeVeR_SeTTLe, Feb 15, 2018 :
    What case do you put on your OnePlus 5T?
  6. alogim Ice Cream Sandwich Feb 15, 2018
    alogim, Feb 15, 2018 :
    I have no damage so far, and I do not even use any type of case. The only thing I find a little uncomfortable is the fact that the camera, since it protrudes a little, tends to make the phone unstable on a flat surface.
  7. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 15, 2018
    I think that is a nonexistent problem :)
    If it is uncomfortable for you, put your device screen flat.
    faithiee likes this.
  8. alogim Ice Cream Sandwich Feb 15, 2018
    It is uncomfortable when you use it on your desk or on a table for example, since when you type it tends to move.
  9. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 15, 2018
    That is why I wrote to put your OnePlus 5T screen flat. Problem solved. ;)
  10. alogim Ice Cream Sandwich Feb 15, 2018
    I don't understand what you mean with "put your screen flat". If you mean knocking over the phone, putting the screen on the table, then again, how can you possibly use it?
    I1512510963799 likes this.
  11. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 15, 2018
    Putting your devices screen flat on the table.
  12. G_Anthony_Waterhouse_Rzp Cupcake Feb 15, 2018
    G_Anthony_Waterhouse_Rzp, Feb 15, 2018 :
    I use the one plus standard black sandstone case and I would expect to see some chippie, pitting on the back as I use my phone in a dusty environment on occasions but nothing as yet
  13. alogim Ice Cream Sandwich Feb 15, 2018
    Sorry, I still don't understand what you mean.
    Let me explain again: I often use my phone on my desk, without keeping it in my hands, I just put it on the desk. The back of the phone is in contact with the surface of the desk. However, when you use it, especially when you swipe or tap, the phone moves, because the camera is a little protruding. To make the phone stable, you have to either put it in a case or carve the table (a thing I don't think you should do :D) to compensate the protrusion.
  14. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 15, 2018
    I totally understand what you are saying :) I am saying to do this:
    I understand you don't want to do it like that because you want to be able to SMS on your phone when someone sends you a message. So you have three options:
    1. Put a case
    2. Put phone face down
    3. Carve the table :D
    4. Use a phone stand ;)
  15. do the joj Gingerbread Feb 15, 2018
    do the joj, Feb 15, 2018 :
    This is normal, it happens due to the fast charging being used (haha yes I also love me silicone cases) its perfectly normal for heat is made during charging and it's probably your first time to notice it
