Heating Issue and Battery draining
  1. V1513646620958
    Donut Mar 20, 2018
    V1513646620958 , Mar 20, 2018 :
    Hi,
    Suddenly my mobile is getting heated and my battery is draining. Within 3 hours my battery is down to 50% without using any game apps.
    Regards
    Naresh
  2. GokuUltraInstincts
    Jelly Bean Mar 20, 2018
  3. KDP1
    Cupcake Mar 20, 2018
    KDP1 , Mar 20, 2018 :
    hi team
    facing same issue I took phone a month back
    battery is getting drained within 2-3 hours
    please address immediately
  4. Waveform Modifier
    Marshmallow Mar 20, 2018
    Waveform Modifier , Mar 20, 2018 :
    Do you read?
  5. Sreyas K Sunil
    Honeycomb Mar 20, 2018
  6. Waveform Modifier
    Also, what team? Only user community here. 1+ dev never read this forum. And who do you think you are to demand anything from the user community?
  7. W1519470867540
    W1519470867540 , Mar 20, 2018 :
    Hi. I had the same issue after update to android 8.0 and started from battery info. It says that "android system" process drains battery a lot. Then I noticed that the free space of my storage is extremely low and there's the folder "oem_log" or just like that is too big. I found info in this forum that could help turn off logging of system.If you have the same folder with big files in it, it means you have the same issue. So you should do the next steps:
    1. Go to your standard phone dialer and type *#800#
    2. In opened menu go to "oneplus Logkit" and check "save log", and uncheck it again ( I had logging with this unchecked option somehow)
    3. Then go down to "advanced" and then to "save log type" and uncheck all the parameters.
    Now I have long battery life, big free space and no more folder "oem_log".
    I hope this info helps you.
    KDP1 likes this.
  8. W1519470867540
  9. K1515151836511
