Happyfire , via OnePlus Nord 2 , Aug 13, 2021 : Hello. I bought new OnePlus Nord 2 today. I can feel some warm heat in middle of the phone continuously. I'm justing using Instagram and what's app in 60hz only. I also completed all the system updates
drl431 , Aug 13, 2021 : Hi, assuming you did not install a misbehaving app (or transfer apps from an old phone), allow 2 or 3 full battery cycles for the system to finish setup after any update.
drl431 , Aug 13, 2021 : No problem with transferring data, but transferring apps, that may not be compatible with the current Android version (or the phone itself) can cause problems.
Happyfire , via OnePlus Nord 2 , Aug 13, 2021 : So, I will try to use for next 2-3 battery rounds. And back to you
