Heating, Lag's and Battery drain via OnePlus 8 Pro
  1. HetSalaaa
    Eclair Apr 25, 2021
    HetSalaaa , via OnePlus 8 Pro , Apr 25, 2021 :
    After updating the lastest version I am facing Heating, Lag and Battery drain problem.
    While charging the phone it get heating even in idle something getting heat.
    When we are using WhatsApp or different apps it get crush and lag we have to have for a minutes sometime UI is stopping.
    For the last Battery drain is like pouring water from the bottle.
    Can anyone solve this problem? I will be very thankful to you if you can solve the problem.
    Thank you
    Joe Lyan Sanate Hmar
    India
  2. drhemani
    Honeycomb Apr 25, 2021
    HetSalaaa likes this.
