hectic day with op3
  1. Dharmraj Jeurgi
    Gingerbread May 7, 2017
    Dharmraj Jeurgi , May 7, 2017 :
    today I got bad situation with op3 it's irritated automatically screen on and off I couldn't do anything thing, can't open lock also.....it's very very bad one plus
    Aakash jha likes this.
  2. hahaha2223
    Jelly Bean May 7, 2017
    hahaha2223 , May 7, 2017 :
    first, I cant really understand this, but a long press of the powerbutton should be a possible fix
    Bobbie63 likes this.
  3. SilverGlove
    Ice Cream Sandwich May 7, 2017
    SilverGlove , May 7, 2017 :
    His Screen is randomly Switching on and off
    Bobbie63 and Sun90 like this.
  4. adpro
    KitKat May 7, 2017
    adpro , May 7, 2017 :
    Did you try restarting your device?
    Is it only screen switching on and off or the phone itself?
    varma246, Bobbie63 and Sun90 like this.
  5. vintagetech
    Honeycomb May 7, 2017
    vintagetech , May 7, 2017 :
    I would suggest you long press the power button to restart your OnePlus 3.
    I use the "restart" option once a day with all of my smartphones. By restarting my phone once a day, you give your phone the opportunity to clear memory and start fresh.
    You could try clearing the all programs cache and then restarting your phone.
  6. Dharmraj Jeurgi
    not switch on off its only display on off can't unlock phone,even after restart
  7. Dharmraj Jeurgi
  8. Dharmraj Jeurgi
    I do same daily
  9. vintagetech
    Maybe you should contact oneplus support sooner rather than later. Your phone might have a bigger issue.
  10. Dharmraj Jeurgi
    after reset setting it get started ....but today too much hectic with my phone
    I did not get it what happened to my phone. I always using very neatly my phone .
    data is safe but all apps are destroyed.
  11. adpro
    KitKat May 7, 2017
    Just delete system data from settings. It will fix most probably.
    Ps: you will lose all your downloaded apps.
    If it doesn't help, then go for full reset.
    Even OP customer care will tell you to factory reset only.
