Help, add Theme Button in Quick Settings via OnePlus 6T
  1. M1542781786674
    Donut Sep 29, 2020
    DroidOnePlus likes this.
  2. camohan
    Marshmallow Moderator Sep 29, 2020
    camohan , Sep 29, 2020 :
    Hi there, I'm not sure what is the theme button option. Probably it's a third party app thing. If you want to add that button, you pull the notification shade, look for a pencil icon, the shade will expand, scroll left and right to find the button you are looking for and long press, drag it up to place on main tiles.
    Hope this is what you are looking for.
  3. M1542781786674
    Donut Sep 29, 2020
    M1542781786674 , via OnePlus 6T , Sep 29, 2020 :
    Cant find theme in it, i wama get quick access to theme option in settings.... Through notification slide
  4. Tokolozi
    Marshmallow Sep 29, 2020
    Tokolozi , Sep 29, 2020 :
    What theme do you mean? Like dark mode or something else?
    Caomhin and M1542781786674 like this.
  5. camohan
    Oh wait, are you requesting for a feature to add theme option in slide down tiles?
    Caomhin likes this.
  6. rhyd1am
    Jelly Bean Sep 30, 2020
    rhyd1am , via OnePlus 6T , Sep 30, 2020 :
    There is no QS tile to toggle light and dark mode. However there are spots on the playstore that can give that option (ADB is usually required though).
    Caomhin likes this.
  7. DroidOnePlus
    Honeycomb Sep 30, 2020
    DroidOnePlus , Sep 30, 2020 :
    It is not available in OOS for op6 because their developers are so incompetent to provide basic android 10 features to its os instead they hype on useless & rarely used gimmick features like work life balance & zen mode etc which can be easily achieved by simply dnd toggles and alert slider.
  8. M1542781786674
    Donut Sep 30, 2020
  9. M1542781786674
    Donut Sep 30, 2020
    M1542781786674 , via OnePlus 6T , Sep 30, 2020 :
    Is there a way to access theme change option with ease?
  10. camohan
    Marshmallow Moderator Sep 30, 2020
    Caomhin likes this.
