Help! After install TWRP recovery phone reboots only to Cyanogen Recovery
  1. vickywaran
    Gingerbread Apr 29, 2015
  2. Yoeri058
    Cupcake Apr 29, 2015
  3. martron
    Cupcake Jun 3, 2015
    martron , Jun 3, 2015 :
    I had this problem, took a few tries to figure out workaround. It boils down to the order that you do things.
    Doing things in this order allowed me to finally boot into TWRP recovery:
    • Picking up where you left off above, right after recover img was successfully transferred, type 'exit,' and the cmd window should close.
    • Unplug USB cable from OnePlus One. Phone screen should still say Fastboot Mode.
    • Hold power button, till device powers down.
    • Press and hold Power & Volume Down.
    Hope this helps someone!
    imranrk likes this.
  4. gusuraman
    Community Veteran Jun 3, 2015
    gusuraman , Jun 3, 2015 :
    COS12 will Always overwrite the recovery.
    To avoid this you mus reboot directly in recovery just after flashing it.
    Doing this the TWRP will automatically patch the ROM to don't revert to the default recovery.
    To do this follow the above post by @martron
    BTW this questio have been aske many times. try searching next time:)
    @dsmonteiro
    @BrettPlusOne
    TeamValor91 likes this.
  5. jingee
    Cupcake Nov 30, 2017
    jingee , Nov 30, 2017 :
    I was having this problem in my xperia active(st17i) while installing cm12.1 over cm11.
    I solved like this: I unpacked the both boot.img in android image kitchen
    cm11 recovery was cwm6.0.5.1.( I liked this to retain over cm12.1)
    In the unpacked files I replaced all files containing word "recovery" to cm11 to cm12.1 boot unpacking.
    Then repacked the cm12.1 boot.img.
    Then I flashed the boot img via adb.
    Then other flashings as usually required. cm12.1 zip and gap zip.
    I found this by doing many things for 3 full days.
    I
