Help! Android launcher sucking battery
  1. Emalinho
    Ice Cream Sandwich Jun 20, 2016
    Emalinho , Jun 20, 2016 :
    Hello guys,
    I am expierencing some difficulties on the new oneplus 3.
    It has been 4 days I have got the device.
    My biggest concern is the screen freezing I am unable to do anything and have to reboot the device until it works. This happens around 4-6 a day.
    Anyone else expierencing this problems I factory reseted the device and its still occuring.
    I am on 3.1.2
    Please share your knowledge.
  2. Lancelot_69
    Lollipop Jun 20, 2016
    Lancelot_69 , Jun 20, 2016 :
    Download Nova launcher and then disable the other launcher
    Emalinho likes this.
  3. Emalinho
    I will give it a try thanks
    Lancelot_69 likes this.
  4. crysen
    Gingerbread Jun 20, 2016
    crysen , Jun 20, 2016 :
    Yep, I'm also using Nova Launcher (Prime)
    Emalinho and Lancelot_69 like this.
  5. Emalinho
  6. Emalinho
    I have dissabled oneplus launcher and using the nova launcher hopefully it will fix the battery drain.
  7. Brent_Fournier
    Cupcake Jun 30, 2016
  8. Pedro120
    Gingerbread Jun 30, 2016
  9. Benjos
    Honeycomb Jun 30, 2016
    Benjos , Jun 30, 2016 :
    You can also try google now launcher. Clear catche via recovery...
  10. TlathamXmahtalT
    KitKat Jun 30, 2016
    TlathamXmahtalT , Jun 30, 2016 :
    Weirdly enough, I had 2 days in a row where the phone would lock up requiring a reboot every few hours. But since then I haven't had a problem.
    And I use Nova Launcher, so I'm not sure what the deal was.
  11. G_Brian_Palladino_Evqs
