HELP Can't add apn settings
  1. DomagojMartinovic_MC024
    Donut Jan 9, 2019
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jan 9, 2019
    Artemus , Jan 9, 2019 :
    What happens when you try to add them?
  3. The1Lion
    Marshmallow Jan 9, 2019
    The1Lion , Jan 9, 2019 :
    Make sure you press the 3 dots in the upper right corner and select save, it's not obvious that you need to do that and if you back out you're settings will be lost
    Artemus likes this.
  4. DomagojMartinovic_MC024
    Donut Jan 9, 2019
    DomagojMartinovic_MC024 , Jan 9, 2019 :
    Kytharsis
    What happens when you try to add them?​
    i go to + type everything that need and go to tre dots -> save but nothing happeneds
    the new settings doesn't show
  5. The1Lion
    AS soon as you press "Save" it should return to the APN's screen showing the new APN you just setup and you then select it.
  6. DomagojMartinovic_MC024
    Donut Jan 9, 2019
    yeah i understand that but it's doesn't show
  7. DomagojMartinovic_MC024
    Donut Jan 9, 2019
    yeah i solve it.....somewere in this forum :
    There are settings at the bottom of the APN settings screen. Unless you put something in the MVNO type field then it does not save. I selected IMSI from the available options. Then it will save. Do not worry about MVNO value, that self-populates. This enabled me to add the correct APN settings for my carrier. Now my Data Roaming works too!!!!
    nige159 and D. Howard like this.
  8. The1Lion
    That's odd, mine will save with that not being set :confused: But glad you have a solution!
  9. paupsman
    Cupcake Jan 10, 2019
    paupsman , Jan 10, 2019 :
    try this go into your phone dialer and enter *#*#info#*#* which will bring up the attached
    HenryGodboltIV likes this.
  10. HenryGodboltIV
    Eclair May 21, 2019
    HenryGodboltIV , May 21, 2019 :
    Thank you so much! This worked! My speeds were 10 Down 7 Up and now theyre 47 down 40 up as it should be! Thanks again!
    Is there a way I can "un-greyout" Wifi calling provisioned?
  11. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator May 22, 2019
    Artemus , May 22, 2019 :
    Only if your carrier supports it.
  12. akshaykumarhs
    Cupcake Jun 27, 2019
    akshaykumarhs , Jun 27, 2019 :
    It worked for me as well. I use Lycamobile UK and use oneplus 7.
  13. T1579837522092
    Cupcake Jan 24, 2020
    T1579837522092 , Jan 24, 2020 :
    Something else I noticed, if you don't remove the automatically set APN it will act like it's not adding, but if your Delete the automatic APN it will show you other APNs and allow you to set one.
  14. D1546642028950
    Cupcake Feb 15, 2020
  15. drummingchef
    Eclair Nov 2, 2021
    drummingchef , via OnePlus 6T , Nov 2, 2021 :
    This is quite interesting! I'm tempted to update my 6t to OOS 11 but am very weary to do so because of this bug with certain Canadian carriers with it deleting the APN settiings.
