3
[HELP] Can't update my Oneplus 3!
  1. G_Juan_Madera_qpYg
    Cupcake Dec 6, 2016
    G_Juan_Madera_qpYg , Dec 6, 2016 :
    I have this problem since day one. The stock recovery fail every time I try to update, manually or auto. The only way to install the updates is installing TWRP recovery, full wipe you phone and flash the latest updated image everytime you want an update.
    Please fix the stock recovery for updates.
    #41
  2. Vedang upadhye
    Gingerbread Dec 6, 2016
    Vedang upadhye , Dec 6, 2016 :
    Just download Opera VPN and change your current
    Location to Canada
    Than this issue won't rise again
    #42
  3. G_Juan_Madera_qpYg
    Cupcake Dec 6, 2016
    That is not the problem nor the solution.
    #43
  4. Vedang upadhye
    By doing so you will be able to get the updates.
    The same thing happened with me so
    The same suggestion was also given to me also
    #44
  5. G_Juan_Madera_qpYg
    Cupcake Dec 6, 2016
    You dont understand.
    We are getting the updates, but the phone fails to update.
    #45
  6. Alphay2k
    Cupcake Dec 6, 2016
    Alphay2k , Dec 6, 2016 :
    install it manually go to OnePlus website download the update file it might be of 1.3 GB to 1.5 GB install it using a PC or laptop u can find some tutorials on YouTube I think this will help a little
    #46
  7. MAS IV
    #47
  8. G_Juan_Madera_qpYg
    Cupcake Dec 6, 2016
    I've follow the tutorial correctly trying to installing the updates manually. The stock recovery update fails everytime.
    #48
  9. Vedang upadhye
    Gingerbread Dec 7, 2016
    Vedang upadhye , Dec 7, 2016 :
    Than I apologize
    #49
  10. Deactivated User
    Dec 7, 2016
    #50
  11. G_Juan_Madera_qpYg
    Cupcake Dec 9, 2016
    G_Juan_Madera_qpYg , Dec 9, 2016 :
    No, It doesnt.
    #51
  12. t0nnizi
    Donut Jan 10, 2017
    t0nnizi , Jan 10, 2017 :
    I it doesnt update 4.0.1, update saying instalation failed. How to fix?
    #52
  13. rcsiberia
    Cupcake Feb 14, 2017
    rcsiberia , Feb 14, 2017 :
    OnePlus3Oxygen_16_1702081756; firstly downloaded 90Mb file, but failed to update, then downloaded 1.4Gb file, but failed to update as well. I'm quite irritated already; PS: the phone is full stock, just installed few games and made few pictures and videos using the camera. Also I have a pin code to enter the phone(if it matters)
    #53
  14. ghostofcain
    Marshmallow Feb 14, 2017
    ghostofcain , Feb 14, 2017 :
    Go to release thread download full zip file you will find there and try applying local update, if that doesn't help try sideloading via recovery.
    #54
  15. rcsiberia
    Thanks, Just adb install worked for me. Btw the instruction on the site has wrong texts. Item in the recovery menu called install from ADB or so, not "install from USB" as stated in the instruction. Also the question "Reboot - Yes" after installation is wrong. becuase it should be "Reboot - No". First time when you click "yes" it means "no". The second time it asks question with proper answers :"Reboot-No". Also I would expect that update is working properly on my device since it's quite new and standard;
    P.S. also linux command is wrong. It should be the same as windows; adb is a package so you do not need to put ./ before it
    #55
  16. luikamlee
    Cupcake Feb 15, 2017
    luikamlee , Feb 15, 2017 :
    I confirm by changing VPN to Canada., I am able to update.
    #56
    Vedang upadhye likes this.
  17. quofeng
    Cupcake Mar 24, 2017
    quofeng , Mar 24, 2017 :
    After downloading, try turning off wifi before pressing the reboot to upgrade
    #57
  18. G_Defiant_Dude_kXJi
    #58
  19. G_Nirupam_Biswas_vOBo
    Cupcake Apr 19, 2017
    G_Nirupam_Biswas_vOBo , Apr 19, 2017 :
    I got the OTA update few days back. I am facing this exact same issue.
    #59
  20. danbonta
    danbonta , Apr 19, 2017 :
    #60
