Help! Chrome not working! via OnePlus 7T
  1. TheTheeng2
    Donut Aug 24, 2021
    TheTheeng2 , via OnePlus 7T , Aug 24, 2021 :
    My chrome isn't loading pages anymore whereas other browsers are. Rebooted the device, cleared cache and data. Didn't work.
    Anyone, having the same issue??
    DaveKaz likes this.
  2. Sheppards
    Jelly Bean Aug 24, 2021
    Sheppards , via OnePlus 7T , Aug 24, 2021 :
    The error messages says "timeout"
    And also says that you should check your internet connection said:
    Are there any settings you changed?
    uninstall and reinstall chrome, it should set everything back to defaults
    Aaron2017 likes this.
  3. DaveKaz
    Eclair Sep 2, 2021
    DaveKaz , via OnePlus 8 , Sep 2, 2021 :
    Yes mine is doing the same. But on wifi it works
    5g doesn't but everything else is. I uninstalled update but nothing . About to reset
  4. nbrincat
    Cupcake Sep 3, 2021
    nbrincat , via OnePlus 7T Pro , Sep 3, 2021 :
    When these types of things occur I'd always recommend trying a different browser as well to further diagnose where the issue lies, something like opera, opera gx, brave etc anything chromium based so that you get an idea of if it's the phone or if it is the browser itself. given that you said other browsers are working could you share which ones did work and what chrome version you are on? 🙂
  5. we_need
    Gingerbread Sep 10, 2021
  6. bond007
    Eclair Oct 25, 2021
    bond007 , via OnePlus 7T , Oct 25, 2021 :
    I have the same, with other browser there is NO problem, already did install ( remove update), delete cache, etc
    Error ERR_CONNECTION_TIMED_OUT
    What can I try, this started I think 1 week ago.
  7. Tim vd Wolfshaar
    Cupcake Oct 26, 2021
    Tim vd Wolfshaar , Oct 26, 2021 :
    Hello i found the awnser.
    Go to settings > apps then select chrome en go to the settings from the chrome app then there is a button called wifi you turn that off or on. Gl!
