Help... Formatting Oneplus 3T COMPLETELY.
  1. simonbyrial
    Cupcake Mar 20, 2018
    simonbyrial , Mar 20, 2018 :
    Hello,
    I'm have had a lot of problems with my phone over the last few months and I have now come to the conclusion that I have to start completely from scratch.
    Problems include:
    • Random reboots
    • Slower overall performance
    • System partition is corrupt (however still able to boot)
    • Not able to uninstall or install anything Xposed related including Xposed itself (because of courrupt system partition)
    Now, if anyone knows how to fix the problems that would be awesome. I'm willing to go all the way and loose all data if I have to. The only thing I want to avoid is a bricked phone.
    When I say format phone I mean FORMAT phone. This means all the partitions need to be formatted. After this is done I have to install new OEM, OS etc. (a guide on that would be helpful too ;D)
    Details about phone:
    • Running Android 7.1.1 with OxygenOS 4.5.1
    • Hardware Back/Multitasking buttons don't work (because of me breaking them... Derp)
    • TWRP 3.2.1 is installed
    • SuperSU/Root is installed
    • Xposed installed
    • I have fastboot driver installed and ready on my PC.
    • All data in Internal Storage is backed up.
    Thanks,
    Simon
  2. Sridhar Ananthanarayanan
    Lollipop Mar 20, 2018
  3. Petjitsu
    KitKat Mar 20, 2018
    Petjitsu , Mar 20, 2018 :
    TWRP - Wipe - Data Format ....
    TWRP - Wipe - Advanced Wipe ....
    Apply only when you know what you are doing !!! ;)
