[HELP] Icons stuck!
  1. ExquisiteMango
    Gingerbread Sep 26, 2015
    ExquisiteMango , Sep 26, 2015 :
    Some background: So I'm on the 12.1 nightlies and I have the full gapps so that means trebuchet has been replaced by Google now launcher.
    Problem: I'm currently using the Yitax icon pack by Vertumus. However when I try to change my icon pack in the theme manager, it says its changed but the Yitax icons are still there, yet in the 'Apps' section in setting, they get changed.
    I've also tried uninstalling Yitax, but nothing, its still there. I've also tried clearing the cache and Dalvik cache using TWRP, still nothing.
    Has anyone had this issue or know how to fix it?
  2. jstepa
    KitKat Sep 26, 2015
    jstepa , Sep 26, 2015 :
    Try to flash theme chooser extracted from COS 12:
    https://forums.oneplus.net/threads/share-cos-12-app-themer-for-all-cm-12-x-roms-universal.344636/
    Change the icons there and see if that helps.
  3. ExquisiteMango
  4. jstepa
    KitKat Sep 26, 2015
    If you flashed the theme chooser, try to change into another theme without changing anything (whole theme).
    If you don't have anyother theme, install some from playstore.
  5. ExquisiteMango
  6. jstepa
    KitKat Sep 26, 2015
    And if you re-install icon pack and then change the whole theme?
  7. ExquisiteMango
    Gingerbread Sep 27, 2015
  8. jstepa
    KitKat Sep 27, 2015
    jstepa , Sep 27, 2015 :
    Can't see another option than clean install, it's buried too deep...
  9. ExquisiteMango
  10. jstepa
    KitKat Sep 27, 2015
    One thing you might try before clean flash, is dirty flash your current ROM, just wipe cache and Dalvik after that.
  11. ExquisiteMango
    Gingerbread Sep 28, 2015
  12. jstepa
    KitKat Sep 29, 2015
    jstepa , Sep 29, 2015 :
    Sorry, clean flash then :(
  13. Maria Pap
    Honeycomb Sep 29, 2015
    Maria Pap , Sep 29, 2015 :
    Its a bug with the latest version of Google now launcher. Many people are facing this issue, including myself. The only way to change icon pack is to clear data of the Google app and then reboot
  14. ExquisiteMango
    Gingerbread Sep 30, 2015
    ExquisiteMango , Sep 30, 2015 :
    Thanks for the update! I'm glad I'm not the only one with this issue
  15. ExquisiteMango
  16. Maria Pap
    Honeycomb Sep 30, 2015
    Maria Pap , Sep 30, 2015 :
    The Google app, if I remember correctly. Did you have any luck?
  17. Deadclysm
    Froyo Sep 30, 2015
    Deadclysm , Sep 30, 2015 :
    I'm pretty sure you need to reboot phone in Google Launcher App in order to get it to work.
    ExquisiteMango likes this.
  18. JHannaman82
    Eclair Oct 23, 2015
    JHannaman82 , Oct 23, 2015 :
    I had this same issue. Your solution worked for me. Thank you so much for contributing!!!
    Maria Pap likes this.
  19. Maria Pap
    Honeycomb Oct 24, 2015
    Maria Pap , Oct 24, 2015 :
    Glad I could help!
