Help me out, how to make back up when screen is broken.
  1. jeroenraap
    Eclair Sep 6, 2015
    jeroenraap , Sep 6, 2015 :
    Hello community,
    My OnePlus One recently flew through the air and landed on pavement. The screen is broken... I am not able to preserve good things for too long. :( My screen still works but it won't react on touch. Now i wonder if there is a way to control my OPO without touch because I want to make a backup and save the pictures on my computer. Are there people who can help me out?
    Looking forward to your replies!
    Greets
  2. polk03
    Honeycomb Sep 6, 2015
    polk03 , Sep 6, 2015 :
    If you enabled USB debugging, you can connect to PC and exchange data there.
  3. Kapitan Nemo
    Lollipop Sep 6, 2015
    Kapitan Nemo , Sep 6, 2015 :
    If he doesn't have it enabled and the touch screen is not functional anymore the only way is to move files through adb command lines.
    Good luck!
  4. jeroenraap
    Eclair Sep 6, 2015
    t
    That does not work, I guess because my phone is secured with a password.
  5. polk03
    You should have added a smartlock. My OPO unlocks with my face and home WiFi. Its too late for that.
  6. Deactivated User
    Sep 6, 2015
    AmelieA, jeroenraap and Kapitan Nemo like this.
  7. jeroenraap
    Eclair Sep 6, 2015
    I will look for that one!
  8. jeroenraap
    Eclair Sep 6, 2015
    found out we don't have one, was thinking it might be possible via computer
  9. Deactivated User
    Sep 6, 2015
  10. thenicologix
    Gingerbread Sep 6, 2015
    thenicologix , Sep 6, 2015 :
    how can you unlock it with your home wifi?
  11. jeroenraap
    Eclair Sep 6, 2015
    with smartlock in settings, shows itself
  12. jeroenraap
    Eclair Sep 6, 2015
    Thanks for your reply, I tried using abd but usb debug is enabled so it doesn't work. Is there a way to turn usb debug off without using the touch pad. My phone is rooted.
  13. TheManDroid
    TheManDroid , Sep 6, 2015 :
    Download and install Mobogenie for PC and that should help you with what you need to do.
    jeroenraap likes this.
  14. thenicologix
    Gingerbread Sep 7, 2015
  15. thenicologix
    thenicologix , Sep 7, 2015 :
    I found the settings but it's by locating your phone and not via WiFi
  16. jplwolters
    Eclair Sep 7, 2015
    jplwolters , Sep 7, 2015 :
    Its mutch easyer than using ADB settings. Just plug in a computer mouse using a OTG cable. Then you can just point and click like you would normaly do with your fingers. The mouse also works in the recovery :D
  17. Ashwith
    Jelly Bean Sep 7, 2015
    Ashwith , Sep 7, 2015 :
    Sorry to hear that buddy. Luckily my OPO survived a similar fall without any damage.
  18. taka61
    taka61 , Sep 7, 2015 :
    not wifi just bluetooth and nfc?
