Help me to fix this issue.
  1. Subhadip Mistry Gingerbread May 22, 2019
    Subhadip Mistry, May 22, 2019 :
    Please anybody help me to solve this issue. When I take picture then this orange shadow is appearing in the upper side of the image.(Nothing is sticking on the camera).
  2. DVNK09 Honeycomb May 22, 2019
    DVNK09, May 22, 2019 :
    Something may be wrong with your camera. Look into sending it in for repair.
  3. Subhadip Mistry Gingerbread May 22, 2019
    But I think this is in software, because when I use the Google Camera port then nothing happens.
  4. DVNK09 Honeycomb May 22, 2019
    Ahh okay with that information I would suspect that as a software bug. Disable camera and clear all data then reuse.
  5. Subhadip Mistry Gingerbread May 23, 2019
    Subhadip Mistry, May 23, 2019 :
    OK
  6. M Mihai Tudor Froyo May 23, 2019
    M Mihai Tudor, May 23, 2019 :
    It looks like when you partially forget your finger on the camera when you take photos...
    But also... I encountered this tinting issue on a phone that had flip/wallet case. The cutting around the camera was to tight.
  7. Subhadip Mistry Gingerbread May 24, 2019
    Subhadip Mistry, May 24, 2019 :
    Ya...I thought this at first but I retake the picture and same problem there.
