Other Help me turn on my oneplus 6!
  1. Moenh
    Donut Oct 19, 2019
    Moenh , Oct 19, 2019 :
    Hello! Last night my phone fell on the volume rocker/changer. The volume down button got bent into the frame and is like sitting still with the frame, so volume button is always pressed in. I had some issues locking my phone with the phone button and got a bunch of bug reports made within 5 mins, so I decided to re-start the phone and that ended in the phone getting stuck into a boot-up mode where you have to navigate with volume down/up to select the mode to restart. But it keeps circulating through all the start up modes.
    Unfortunately I live in Lebanon, middle east so I don't know how I'll fix it but if someone can navigate me through a way to force start my phone possibly with my PC through some software. I'd greatly appreciate any advice on this.
  2. Kytharsis
    Marshmallow Oct 19, 2019
    Kytharsis , Oct 19, 2019 :
    You might be SOL if the volume button is permanently pressed-in.
    Moenh likes this.
  3. B_Wrath
    B_Wrath , Oct 19, 2019 :
    Nope. Unfortunately, you have to take your phone to some service center. It's a physical damage.
    You can gently try to pull the volume button back to normal position.
  4. Moenh
    Donut Oct 19, 2019
    Thank you guys. Had to take it to a local shop they bent it sorta straight back into a functional position.
