help me via OnePlus 7T
  1. Amit47
    Cupcake Jun 1, 2020
    Amit47 , via OnePlus 7T , Jun 1, 2020 :
    Sir . Mera airtel ka sim h, streaming or download speed acha h 3,4 Mbps ata par v pubg m pining problem h 800 , 900 ata h kya problem h ,, ky sim k hardware m problem h or kuch PLZZ help me . I am using OnePlus 7t
  2. G.Madhusudhan
    Gingerbread Jun 1, 2020
    G.Madhusudhan , via OnePlus 7T , Jun 1, 2020 :
    yee tho Network issue , Airtel , jio dono kya karthe hey .. speed kam karthe kuch download ke baad , it's not hardware issue , it's network issue bhai
  3. Cosmos_NT , via OnePlus 7T Frosted Silver , Jun 2, 2020 :
    Try Fnatic Mode - it might just help you but still it is not clearly a solution. But make sure you read it's instructions/warnings as it does help improving network strength, it will disable your 2nd sim card during Fnatic Mode usage (it will come back within a minute once you turn Fnatic off)
    Also, not sure if this will work or not but in my case it does sometimes - try VPN.
    Amit47 likes this.
  4. domestoboto
    Gingerbread Jun 3, 2020
    domestoboto , via OnePlus 7T , Jun 3, 2020 :
    It's a network problem. And also maybe, just maybe, PUBG "Mobile" is just a little bit crap. Because people are getting below 100 ping on Fortnite and COD "Mobile", for example.
    Amit47 likes this.
  5. Aviroop96
    Donut Jun 3, 2020
    Aviroop96 , via OnePlus 7T , Jun 3, 2020 :
    1. Settings - System -Reset - Reset mobile, wifi and Bluetooth.
    2. try changing servers/region of PUBG from Asia to any other region and see if it helps or not.
    3. Try with/without fanatic mode.
    if these doesn't work, then this is definitely a network issue
    Amit47 likes this.
