Help..mirror effect on front facing camera. taken photo shows other way round
  1. murshid11
    Honeycomb Oct 10, 2014
    murshid11 , Oct 10, 2014 :
    Hi guys, I get kid of a mirror effect on my front facing camera after latest firmware update. Normally when u take a picture it should show as it is, here's mine shows like that I have taken it from the other side ex. Take a selfie with a car on ur left shows it has taken from the right side.
  2. murshid11
  3. Sandesire
    Jelly Bean Oct 10, 2014
  4. murshid11
    Did u check ur camera, is it working properly after the update
  5. johnnymartz3
    johnnymartz3 , Oct 10, 2014 :
    I had that problem with my old gs4. I had to go into camera settings and change the way it stored the images
  6. Silverchaoz
    Lollipop Oct 10, 2014
  7. Sandesire
    Sandesire , Oct 10, 2014 :
    Nope, same here. I don't like it, it's natural though.
  8. abrahamsamuel
    Gingerbread Oct 10, 2014
    abrahamsamuel , Oct 10, 2014 :
    Place the phone in front of a mirror and retake the picture. This should do the trick.
  9. emtykax
    leemartin likes this.
  10. murshid11
    I think camera has gone crazy after the update, its first time I'm facing that issue.
  11. murshid11
    Its not natural bro, if u have another phone try to take a picture and compare..its totally crazy how the front camera behave after update
  12. Sandesire
    Make a selfie and let another person make a pic of you with the back camera, compare. See what I mean?
  13. mydroid
    KitKat Oct 10, 2014
    mydroid , Oct 10, 2014 :
    just tested its correct image as I used a paper with wordings . while taking selfie its mirror image but photo comes out the correct way.
  14. Reivon Choccoli
  15. dwaynelson
    KitKat Oct 10, 2014
  16. gusuraman
    Community Veteran Oct 10, 2014
  17. mikeneedsaphone
  18. murshid11
    Some people has the same issue, its not exactly a mirror image hatvi meant was u take a selfie u keep bit space on the right side once u take it it shows u have space on the left side
    And if u could read ull see there are more people has the same issue
  19. murshid11
    Rebooted more than 5 times
  20. murshid11
    Is there any way that we can let CyanogenMod people
