HELP! My OP7 Pro's camera better than OP7 Pro McLaren; WHY? via OnePlus 7T Pro
  1. wwg1wga
    Cupcake Sep 25, 2020
    wwg1wga , via OnePlus 7T Pro , Sep 25, 2020 :
    Ok so my OP7 Pro Nebula Blue Global ROM HD1913 unfortunately fell and the digitizer cracked. The phone wasn't able to be used at all. I have had ZERO issues with that phone. I've been using OP faithfully now for awhile. I couldn't make up my mind as to what to do next, so I started using my OP 6T McLaren again.
    Finally because my OP7 Pro was the BEST phone I have ever used, naturally one would think, McLaren must be even better. Well, it's a HUGE disappointed. The phone is unlocked Global ROM HD1910 model and I cannot take consistently nice photos. Honestly, I feel the camera sucks. Night mode doesn't work like the OP7 Pro. There's always an AF issue taking too long or simply not working. Then there's the video, not happy with this either. There's wavy lines in my videos and the stabilization is NOTHING like the OP7 Pro.
    I paid over $1000 USD for this brand new and what the hell.
    Does anyone else have these same issues with the same phone? If so, what's the model #?
  2. Artemus.
    Nougat Sep 25, 2020
    Artemus. , Sep 25, 2020 :
    There's your problem. You paid extra for the branding rather than the phone itself.
  3. wwg1wga
    Quite possible! I'm typically the type researching every spec on a phone. With this McLaren I did not.
    So are you saying this with knowledge that the McLaren is NOT a better phone than the OP7 Pro?
  4. Artemus.
    Nougat Sep 25, 2020
    I mean, it's all subjective really. But generally, don't buy a device based on brand-name alone.
  5. wwg1wga
    I'm in my 40's and haven't done so for years. Possibly did so this time, but, it's not like OP puts out garbage devices. The op6t McLaren is GREAT. Not buying for the name, hence, why I'm buying OP and NOT Apple or Samsung.... Anyhow, thanks for reading, cya
    Artemus. likes this.
  6. Roger.T
    Ice Cream Sandwich Sep 25, 2020
    Roger.T , via OnePlus Community App , Sep 25, 2020 :
    The McLaren is from the year before the 7 Pro released.
    You can't expect the device to be better just because it's more expensive...
    I refer once to the fact that you named the OP6T McLaren in the declaration.
    Many improvements have been made for the 7 series in all areas and also new camera modules .
    So it is only normal that newer models are also better although there are so many complaints in this forum [e]1f609[/e][e]1f601[/e]
  7. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Sep 25, 2020
    Bouncer71 , via OnePlus 7 Pro , Sep 25, 2020 :
    The 7TPro basically has the same camera setup as the 7Pro...
    Except an added macro mode on the wide-angle lens..
    So they should actually have the same image quality...
    What's your camera version...?
  8. wwg1wga
    Cupcake Sep 26, 2020
    wwg1wga , via OnePlus 7T Pro , Sep 26, 2020 :
    Yes the 6t McLaren is about a year older than the 7 series. I'm not talking about the 6 series though. The OP7 McLaren came out AFTER the OP7 Pro and my camera sucks!
  9. Artemus.
    Nougat Sep 26, 2020
    Artemus. , Sep 26, 2020 :
    Download GCam, lots of people find this app a lot more useful.
    Bouncer71 likes this.
  10. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Sep 26, 2020
    wwg1wga and Artemus. like this.
  11. wwg1wga
    Cupcake Sep 28, 2020
    wwg1wga , via OnePlus 7T Pro , Sep 28, 2020 :
    Possibly just need OP to realest a new software update.
    Worse comes to worse I'll just sell this and buy the OP7 Pro
  12. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Sep 28, 2020
    Bouncer71 , via OnePlus 7 Pro , Sep 28, 2020 :
    Again the question...
    What camera version do you have...?
  13. wwg1wga
    Cupcake Sep 30, 2020
  14. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Sep 30, 2020
    Bouncer71 , via OnePlus 7 Pro , Sep 30, 2020 :
    Okay, that's the last stable version...
    First Clear cache and data and see if your issues still persist...
    If so, maybe try the latest 3.10.26 (OB18) from apk mirror..
    This will be installed as an update and can be rolled back to .24 if you face any further issues...
    wwg1wga likes this.
  15. sirtenzin
    Eclair Sep 30, 2020
