HELP my phone is going on and off
  1. greglambert
    Gingerbread Oct 22, 2014
    greglambert , Oct 22, 2014 :
    MY phone is going on and off it boots up for a few seconds then reboots I thought it was software and did a factory reboot and it is still doing it
  2. thyviper
    Jelly Bean Oct 22, 2014
  3. shejduce
  4. DankMagician420
    DankMagician420 , Oct 22, 2014 :
    Try hard reset in recovery mode
  5. lostLambda
    Lollipop Oct 22, 2014
    lostLambda , Oct 22, 2014 :
    Hold down volume button, keep holding it down, then hold down the power button. This will give you a clean reboot.
  6. TitusCromwell
    Honeycomb Oct 22, 2014
  7. imnotarobot123
    Ice Cream Sandwich Oct 22, 2014
    scumdroid likes this.
  8. TheTubTruck
  9. greglambert
  10. greglambert
  11. phonehog
    phonehog , Oct 22, 2014 :
    This happens occasionally on all Android phone.
    Relax, it isn't Ebola. It's your overreaction honey..
  12. scumdroid
    scumdroid , Oct 22, 2014 :
    Never happened to any of my devices. Lrn2Android
    mitha88 likes this.
  13. oscarvanl
    oscarvanl , Oct 22, 2014 :
    You can do a fix through the phone in recovery mode. Firstly try wiping the cache and rebooting into the system. If that doesn't work try doing a full factory reset by wiping everything in recovery. This should fix it without needing intervention from a computer.
  14. greglambert
  15. phonehog
    You must be a lotto winner then...LOL!
    Just happened to my Nexus 4 this AM & went straight to google for help.
  16. greglambert
    it goes into a menue like when I first got the phone I tell it my language then it goes to the next screen and boots again
  17. scumdroid
    Hes been Cyanogenmodded? HUEHUEHUEHUE
  18. scumdroid
    That wasn't directed at you btw ;)[
  19. 8dee
    Eclair Oct 22, 2014
  20. greglambert
