[HELP] Need urgent help
  1. ShrinathMathane
    Eclair Jun 11, 2016
    ShrinathMathane , Jun 11, 2016 :
    HI all one plus 2 users, i have in problem rt now.Today unfortunately i formated my op2 (including system & internal storage).so when i am trying boot it can't it show only one plus logo.BUT fortunately i boot into twrp recovery .SO what i do now to install system in my op2.I am on moki os and rooted before this insident happend. NEED HELP GYUS.
    BY THE WAY I HAVE DOWNLOAD ONE PLUS 2 full 2.2,1 zip file but when i am trying to install it it shows
    mount:failed to mount dev/block/bootdevice/by-name/system at /system :invalid argument
    unmount of system failed no such volume
    patching system image unconditionally ,,,,
    and keep this loading and not move further than this,so what i do now.HELP ME
  2. Alvie
    The Lab - OnePlus 5T Reviewer Jun 12, 2016
    Alvie , Jun 12, 2016 :
    Credit: @Gaurav Rohilla
    ADB SIDELOAD METHOD
    • http://www.technobuzz.net/setup-adb-fastboot-drivers-for-nexus-oneplus-samsung-or-any-android/
    • download these drivers and install them by respectively entering Y for each option offered.
    • switch off your phone completely and boot it in fastboot mode by pressing VOLUME UP BUTTON (keeping it pressed) + POWER BUTTON BUTTON=> release both of them after the phone vibrates. connect it to PC after this.
    • now, open device manager in your PC and check for your device which would might have a yellow exclamation mark or not. then check these GIF's which are self explanatory ( credits: @@DaxNagtegaal )
    • after this, disconnect your phone, switch it off by pressing power button, press VOLUME DOWN(keeping it pressed) + POWER BUTTON => recovery mode. select English>>Install from USB and connect your phone to PC.
    • download fastboot zip from here: http://downloadandroidrom.com/file/tools/fastboot.zip and extract it. inside the extracted folder, press shift (from keyboard and keeping it pressed) +right click from mouse=> open command prompt here and check for the command adb devices , you should get something like this with different characters:
    • minimize this command prompt window and download oxygen OS 2.2.1 zip from here:
      https://www.androidfilehost.com/?fid=24438995911976356 credit @Spannaa
    • and put this zip (without extracting ) inside the fastboot folder.
    • maximize the command prompt window and type the command
      Code:
      adb sideload OnePlus2Oxygen_14_OTA_012_all_1602261837.zip
      and let it execute till 100%. after it has executed completely , reboot your phone to system.
  3. ShrinathMathane
    Eclair Jun 12, 2016
    ShrinathMathane , Jun 12, 2016 :
    I already do this way but it show installation failed.And my adb fastboot allready unlocked .I think my op2 got hard bricked.
  4. Lancelot_69
    Lollipop Jun 12, 2016
    Alvie likes this.
  5. Gonzo01
    Gonzo01 , Jun 12, 2016 :
    it's not bricked. you just don't have OS.
    follow the guide above and flash rom.
    Gaurav Rohilla likes this.
  6. Gaurav Rohilla
  7. Gaurav Rohilla
  8. ShrinathMathane
    Eclair Jun 12, 2016
    after writing on command prompt adb sideload OnePlus2Oxygen_14_OTA_012_all_1602261837.zip
    i getting this massage
    serving OnePlus2Oxygen_14_OTA_012_all_1602261837.zip(~40%)
    and after that
    total xfer: 1.00x &
    installation failed on mobile screen .
    so what i do in this case
  9. Gaurav Rohilla
    Gaurav Rohilla , Jun 12, 2016 :
    use adb push commands. see that thread I pinned.
  10. ShrinathMathane
    Eclair Jun 12, 2016
    i used first methods 1 from this thread but it still not worked for me.so what i do
  11. matt_simpson
    Ice Cream Sandwich Jun 12, 2016
    matt_simpson , Jun 12, 2016 :
    download this and run it with your phone in fast boot mode, then download oxygen on your computer and transfer it on to your phone while in twrp flash it and off you go
  12. dsst22
    Honeycomb Jun 12, 2016
  13. Gaurav Rohilla
    send me your teamviewer ID and password and I'll repair your phone. be fast.
  14. ShrinathMathane
    Eclair Jun 12, 2016
    is it necessary to download 2.1.1.zip of 1.1 gb because i have 2.2.1 naman bhalls full zip .But when i am trying do this with 2.21 i able to get push in sdcard but when trying to flash it showing patching system image unconditionally and keep stuck there i waited 15 min but nothing happend
  15. Gaurav Rohilla
    I told you to flash the rom which you had before and follow those methods just for learning how to..
  16. Gaurav Rohilla
    open teamviewer on your pc
  17. Gaurav Rohilla
    @Shrinath007 adb push the ROM which you had before, no the 2.2.1. I don't which TWRP you're on and the bootloader, just push the zip file of the rom that was there before erasing and flash it.
  18. ShrinathMathane
    Eclair Jun 12, 2016
    i opend the team viewer
    before this insident happend i have os 2.2.1 with mokee rom installed.
  19. ShrinathMathane
    Eclair Jun 12, 2016
    gaurav pm me your cell no I need to talj talk with you in hindi
  20. Gaurav Rohilla
    abhi mai bahar hu bhai dost ke yaha padh raha hu. exams chal rahe hai. ghar aane ke baad assist kar dunga sahi se. oor ye oos 2.2.1 with moke rom installed kya hai bhai? oos2.2.1 ek alag cheez hai, iske sath koi dusra os kaise install kar sakta hai bhai? o_O
