HELP ONE PLUS DASH CHARGE IS NOT WORKING
  1. Android 3t Never settle
    Honeycomb Feb 10, 2018
    Android 3t Never settle , Feb 10, 2018 :
    I recently install the app ampere to see dash charge working or not coz I got the animation of dash charge but it take Soo long to charge my phone from 0 to 100 around 3 hours look what are the results I found
    some people says that it should be arround 3330 ma help me if anyone knows about it
  2. Hydra Bob
    Marshmallow Feb 10, 2018
  3. Android 3t Never settle
  4. Hydra Bob
    Hydra Bob , Feb 10, 2018 :
    Not that I'm aware of. You can always back up your data to a PC, USB, cloud or through other means. It's an inconvenience I know but it seems a small price to pay to me to potentially regain a working device.
  5. Winay00
    Gingerbread Feb 10, 2018
    Winay00 , Feb 10, 2018 :
    Sumdays back my fone was also taking long time to charge & battery was draining quickly.
    But after 1 or 2 days my fone automatically switched off & did not start on pressing power button.
    So i pressed power button & volume button together to boot the fone.
    After that its working fine.
    Try to boot ur fone by pressing volume & power button together.
    See if it can help.
  6. Android 3t Never settle
  7. SanthoshGurram
    SanthoshGurram , Feb 10, 2018 :
    How much time it is taking to charge ur 3T from 0 to 100% ?
  8. Android 3t Never settle
  9. Android 3t Never settle
  10. SanthoshGurram
    Oh is it ? Try to charge with any other Dash Charger if available or try clearing cache from the recovery menu.
  11. Android 3t Never settle
  12. ranjith s
    Eclair Feb 10, 2018
  13. leo98918
    Ice Cream Sandwich Feb 10, 2018
    leo98918 , Feb 10, 2018 :
    Pin possibly broken inside Type-C Port??? This is just me guessing, IDK what else could be causing this besides the charging cable not being fully seated into the phone properly.
  14. jonathanlyng
    jonathanlyng , Feb 10, 2018 :
    DASH does slow down as the battery fills. so that might be it (your phone is at 78% charged 8n the picture, the Amps you are getting are the ones you would find on charging a discharged regular phone battery.
  15. naruto.uzumaki
    naruto.uzumaki , Feb 10, 2018 :
    At most it takes nearly 1.5 hrs to charge from 0 to 100%. Try charging with another dash charger and also other dash charging cable to make sure which part is faulty i.e. either your type-c port or your dash charging cable or your dash charger or two or all of those.
  16. Android 3t Never settle
    ya you are right
    thanks for your help[e]1f60a[/e]
  17. Android 3t Never settle
  18. ranjith s
    Eclair Feb 10, 2018
    ranjith s , Feb 10, 2018 :
    dash charge usb port has 5 pins unlike 4 pins in common usb. one day i partially plugged in the usb port cable it does not detect dash charge. dash cherge needs 5th pin provided with charge cable. because of the 5th pin normal usb cable did not charge in dash mode.
  19. Larry Jones
    Cupcake May 22, 2018
    Larry Jones , May 22, 2018 :
    Check the charging port might be dirty
