[HELP] Regarding Icon Packs for the OnePlus 3/3T
  1. OPO OOS lover
    Jelly Bean Aug 26, 2017
    OPO OOS lover , Aug 26, 2017 :
    If I sideload the APK of icon pack of oneplus 5 into the 3/3T and if I have camera v1.x will the icon look like this?
  2. shollmannr
    Cupcake Aug 26, 2017
    shollmannr , Aug 26, 2017 :
    Yes it will. The standard OnePlus icon pack and not the rounded or square packs will give you that look.
  3. Pr0.ExE
    Gingerbread Aug 26, 2017
    Pr0.ExE , Aug 26, 2017 :
    Why would you need to sideload them? You can easily install the Icons. :D
  4. OPO OOS lover
    Jelly Bean Aug 27, 2017
    OPO OOS lover , Aug 27, 2017 :
    So it will show the same icon if I have camera version 1.4.0
  5. Esmeralda007
    Gingerbread Aug 27, 2017
    Esmeralda007 , Aug 27, 2017 :
    How do you install them? Please let me know.
  6. Pr0.ExE
    Pr0.ExE , Aug 27, 2017 :
    Sure. You can download the Icon Pack from here:
    https://www.apkmirror.com/apk/onepl...-0-170807113031-162608c-android-apk-download/
    Then you just need to touch and hold anywhere on the homescreen. From there you need to select the settings (The gear icon.) then the Icon pack. Now you just need to select Oneplus Icon Pack. You are all set.
    If you want to try out any other pack, you can easily search them on the Play Store. There are lots of good ones. I personally use Omoro and I love it.
  7. Esmeralda007
    There is no icon pack.
  8. Pr0.ExE
    You should update your launcher. But still if it's not under the settings, take a step back and there should be a menu point where you can choose the icons.
  9. Sun90
    Starting Point Expert Community Expert Aug 27, 2017
    Sun90 , Aug 27, 2017 :
    The camera icon of op5 camera is different to the camera icon of Ver 1.3.0.
    pa5t1s likes this.
  10. Esmeralda007
    Nope. How do we update launcher? It's the default launcher that I have now.
  11. Sun90
    You have to download the OnePlus launcher Apk file from Apkmirror site and install it.
    pa5t1s likes this.
  12. Pr0.ExE
    Esmeralda007 likes this.
  13. Esmeralda007
    Pr0.ExE likes this.
  14. OPO OOS lover
    Even I know that but if you install oneplus 5 stock icon pack on the oneplus 3t and if the camera version is 1.3.0 then will it show oneplus 5 camera icon?
  15. Sun90
    You have to install the icon pack to. check.
    pa5t1s likes this.
  16. OPO OOS lover
    Jelly Bean Aug 28, 2017
    OPO OOS lover , Aug 28, 2017 :
    Do me a favor for me just try installing the APK of icon pack of oneplus 5 stock and check whether it shows or not
  17. OPO OOS lover
    Jelly Bean Aug 29, 2017
    OPO OOS lover , Aug 29, 2017 :
    So you say that you have to download Oneplus launcher 2.1.5 only to get oneplus 5 stock icon pack? Is this true @camohan
  18. camohan
    Moderator Moderator Aug 29, 2017
    camohan , Aug 29, 2017 :
    Hi..I already have Op5 running stock icon pack. So really dont kw.
    I think there is no harm in trying this work around of installing the OP launcher and check.
    pa5t1s likes this.
  19. OPO OOS lover
    Jelly Bean Aug 30, 2017
    OPO OOS lover , Aug 30, 2017 :
    What's your launcher version @camohan?
  20. OPO OOS lover
