[HELP] Regarding Icon Packs for the OnePlus 3/3T
  1. Pr0.ExE
    Gingerbread Aug 30, 2017
    Pr0.ExE , Aug 30, 2017 :
    I installed the launcher update first and then the Icon pack's .apk file. You have to install them after one another.
  2. MarkyPancake
    Honeycomb Aug 30, 2017
    MarkyPancake , Aug 30, 2017 :
    The 3T's default system icons in its stock launcher v1.1.0, are baked into the app itself, because they're not available to select when you install v2.1.5 over the top. You can get the APK for them from APKMirror to make them available in v2.1.5.
    When I installed v2.1.5, only the Dives and Rifon icon packs were available in the launcher settings. If you look in Apps, you'll notice these two packs are installed as separate apps, but there is no system default icon pack app. After I rolled back to v1.1.0, the system default icons was in its settings to select.
    I can't remember if launcher v2.1.5 used either Dives or Rifon by default or whether it had its own system default icon pack, but I remember that there was no system default icon option in its settings until I installed the APK myself, unlike v1.1.0.
  3. OPO OOS lover
    Jelly Bean Aug 31, 2017
    OPO OOS lover , Aug 31, 2017 :
    OK I got that
  4. OPO OOS lover
    [SOLVED] Even if you have stock oneplus 5 icon pack the camera app still shows the old icon (if the version is 1.0.3 or older)
  5. OPO OOS lover
    Jelly Bean Sep 2, 2017
    OPO OOS lover , Sep 2, 2017 :
    Can you send me the screenshot of the icon pack
  6. OPO OOS lover
    Can you send me the screen shot of the icon pack because I asked my friend to send the screenshots but he still did not install the APK of the icon pack
  7. Pr0.ExE
    Gingerbread Sep 2, 2017
    Pr0.ExE , Sep 2, 2017 :
    Sure.
  8. GradusR
  9. OPO OOS lover
  10. Pr0.ExE
    Which clock are we talking about?
    If you're pointing at the App Icon, then yes. It will pretty much stay the same.
    If you're talking about any other UI clock, then I say this: None of the icon packs can change the UI clocks. Only themes or fonts.
  11. OPO OOS lover
    I was talking about App icon. Thanks
    Pr0.ExE likes this.
  12. OPO OOS lover
    Jelly Bean Sep 3, 2017
    OPO OOS lover , Sep 3, 2017 :
    Last question @camohan if you're running stock OOS(OOS 4.1.7) what's the version of the gallery app and if you applied stock oneplus 5 icon pack will the icon of gallery app remain like this-
  13. OPO OOS lover
    Jelly Bean Sep 8, 2017
  14. OPO OOS lover
    Jelly Bean Sep 9, 2017
    OPO OOS lover , Sep 9, 2017 :
    IF you're on OOS 4.1.7 can you check the stock oneplus 5 icon pack gallery
  15. Shaher_N_Shuvo
    Gingerbread Sep 10, 2017
    Shaher_N_Shuvo , Sep 10, 2017 :
    S8 dark icon pack, suggest you[e]1f60a[/e]
    Esmeralda007 likes this.
  16. OPO OOS lover
    Jelly Bean Sep 12, 2017
