Help~RSC Dual Sim~Help
  1. sunonupe
    Cupcake Dec 14, 2019
    sunonupe , Dec 14, 2019 :
    I have a dual sim 7 Pro and I can't get the RCS to work. I have two different mobile providers (TMobile & Singtel). When I reset the phone, it allows me to change it to chat, but moments later, it goes back to the none chat version of the message app.
    Has anyone with a dual Sim been able to get this function to work? Was there anything you've done differently, than a normal download, that I need to try? Please Help...
  2. Pauls7pro
    Pauls7pro , Dec 14, 2019 :
    I'm a noob with smartphones but I'm using dual sim but I don't know what you are referring to, what is RCS?
  3. skip029
    Froyo Dec 14, 2019
  4. RolandKillmon
    Froyo Dec 15, 2019
    RolandKillmon , via OnePlus 7 Pro , Dec 15, 2019 :
    Dual SIM doesn't work with RCS. You have to have a number connected to RCS for it to work, making it to where only one number would work. Also Dual Sims aren't supported yet with RCS.
    sunonupe and Vansh99 like this.
  5. SofaKingLegit
    Cupcake Dec 15, 2019
  6. RolandKillmon
    Froyo Dec 15, 2019
    Might want to check the number listed under Chat because that the number being used to send RCS messages. if the text isn't in dark blue then it's in SMS format. (light blue) You can have Dual Sims and use both one for chat and both for SMS, but one will only show in Chat at the listed number. Unless something has changed in a update or you live outside North America. Haven't seen it possible yet!
  7. sunonupe
    sunonupe , Dec 15, 2019 :
    how did you get it to work? I've tried nearly everything. Did you set it up with one number first, them added the other sim?
  8. sunonupe
    when I have both sim cards in, this is what I get, but when take one out, I actually get it to work.
  9. RolandKillmon
    Froyo Dec 15, 2019
    That is what I was saying above. It isn't supported in North America right now or at lease I have not seen it possible yet with two Sims card. Only one sim can be registered at a time for RCS.
    sunonupe likes this.
