2
help to intall android P
  1. Giombo
    Cupcake Sep 21, 2018
    Giombo , Sep 21, 2018 :
    good evening.
    I have a OnePlus 6 with Android p beta 3. I saw that the stable version came out, but it does not update me. I asked and they say I have to downgrade to Android 8 and then upgrade to 9. Is that true? Could you explain or link me a guide to update the phone?
    And it is normal that an update via OTA will not arrive for us who participated in the beta? Thanks in advance
  2. Claudiu Cioloca
    Froyo Sep 21, 2018
  3. Aks41179
    Jelly Bean Sep 22, 2018
  4. Claudiu Cioloca
    Froyo Sep 22, 2018
    Fredrik_Lindgren and Giombo like this.
  5. chazey2
    chazey2 , Sep 22, 2018 :
    Hey guys , for those of you who are on open beta builds ,you would need wait for the download link to be published on downloads.oneplus.com , and as mentioned in the beta posts ,Moving back to the Official OTA path from the Beta path will require a full install and clean flash (full wipe of all data and cache)
    What's not clear???
    Aks41179 likes this.
  6. Giombo
    Cupcake Sep 22, 2018
    Giombo , Sep 22, 2018 :
    okay, but when I go to install Android 8 there is error (you cant go back)
  7. chazey2
    Try post one of beta thread.
  8. RaGnarOp
    Froyo Sep 23, 2018
    RaGnarOp , Sep 23, 2018 :
    anyway to Protect Data ?
  9. chazey2
    Jelly Bean Sep 23, 2018
    chazey2 , Sep 23, 2018 :
    There is one or two apps that are meant to be able to do full back ups without root but they require the use of a PC as well. Have a Google non root Android back up.
  10. RaGnarOp
    Froyo Oct 16, 2018
    RaGnarOp , Oct 16, 2018 :
    chazey2
    There is one or two apps that are meant to be able to do full back ups without root but they require the use of a PC as well. Have a Google non root Android back up.​
    thanks bro only u came here to help
  11. Hasan Khawari
    Gingerbread Mar 12, 2019
