HELP! TWRP Formatted Data!
  1. TaninAdom
    Donut Jun 25, 2015
    TaninAdom , Jun 25, 2015 :
    i accidently did format data in TWRP,
    how can i install my phone again?
    any comment will be blessed
  2. DaxNagtegaal
    Marshmallow Jun 25, 2015
    DaxNagtegaal , Jun 25, 2015 :
    Use my signature guide.. And you're supposed to format data when flashing another ROM so idk what you were doing..
  3. Enyalius
    Jelly Bean Jun 25, 2015
    Enyalius , Jun 25, 2015 :
    It's just apps and data. You can boot your phone and start installing everything again. Or restore backup if you have one :)
  4. TaninAdom
    Donut Jun 25, 2015
  5. TaninAdom
    Donut Jun 25, 2015
    in the "Wipe" option there is "Advanced Wipe" and "Format Data" i choosed Format Data, is my IMEI is DEAD? IS MY PHONE DEAD?
  6. Jawad973
    PRK.R likes this.
  7. matt_simpson
    Ice Cream Sandwich Jun 25, 2015
  8. gjegadeesh
    gjegadeesh , Jun 25, 2015 :
    follow the instructions..Yes. He has done a wonderful job for us..
    PRK.R and DaxNagtegaal like this.
  9. TaninAdom
    Donut Jun 25, 2015
  10. Gonzo01
    Lollipop Jun 25, 2015
    Gonzo01 , Jun 25, 2015 :
    download on your PC flashable zip of rom. reboot to TWRP. connect phone and transfer zip to internal storage. disconnect. tap "install" on TWRP, tap the zip. when extracting is done, tap "wipe dalvik", then reboot to system. that's all.
    PRK.R likes this.
  11. DaxNagtegaal
    Just follow my guide it's not hard to follow
    NaterTots, rez1_k and PRK.R like this.
  12. TaninAdom
    Donut Jun 25, 2015
    Gonzo01 likes this.
  13. TaninAdom
    Donut Jun 25, 2015
  14. dsmonteiro
    Community Consultant Community Expert Jun 25, 2015
    dsmonteiro , Jun 25, 2015 :
    With a cable.
    It shows up as a device, provided you have the MTP drivers installed. As @DaxNagtegaal said, follow his guide.
  15. Gonzo01
    PRK.R likes this.
  16. rikardo1979
    Lollipop Community Expert Jun 25, 2015
    rez1_k, Gonzo01 and PRK.R like this.
  17. TaninAdom
    Donut Jun 25, 2015
  18. AntMunny
    KitKat Jun 25, 2015
    AntMunny , Jun 25, 2015 :
    twrp is mtp enabled
    after you connect your phone to the computer, you can always drag and drop a rom and gapps into internel storage
    then flash it. i don't think you even have to reboot to recovery after putting the rom and gapps onto internal storage
    rez1_k likes this.
  19. TaninAdom
    Donut Jun 25, 2015
  20. AntMunny
    KitKat Jun 25, 2015
    hmmm...in twrp, can you reboot into recovery? and don't install supersu if it asks you to.
    you should be able to drag and drop afterwards
    rez1_k likes this.
