Other Help! Unbrick OnePlus 6T
  1. F1542723991830
    Cupcake Nov 13, 2019
    F1542723991830 , Nov 13, 2019 :
    After Installing OOS10 i find it buggy (always bootloop) so i decided to roll back to Stable Pie.
    I power off my 6T and use the MSM Tool to recover my phone (since i cant do a local downgrade)
    The MSM Tool shows "Sahara Communication Failed" no matter what i do, i ve installed the drivers.
    I unplugged it and tried it several times but is the same, and its even worse, i cant turn on my phone, only connecting to PC makes the connected "sound"
    Pls Help Me!
  2. subhamshaw
    Cupcake Nov 14, 2019
    subhamshaw , via OnePlus 6T , Nov 14, 2019 :
    make sure in device manager you don't see an error when you connect in EDL mode .
    just to be sure
    install Qualcomm drivers for one plus 6t from internet
    don't open msmtool yet
    open device manger
    while holding both vol buttons at the same time connect to pc .
    check in ports that there are no errors of the Qualcomm drivers
    then open your msmtool and click start
    Caomhin likes this.
