12
Help us improve and get gifts - OnePlus 7T Pro 5G McLaren
  1. G1572469583021
    Gingerbread Mar 30, 2020
    G1572469583021 , Mar 30, 2020 :
    I will update and see what it does and I will try speed test. I meant to say chassie partition wipe if you look up how to do a chassis partition wipe online but you do it by powering off your phone then when you turn your phone back on hold the power button and the volume up button at same time till the phone turns on. that will get you into the bootloader they're going in your PIN if you have one or password then you're going to pick English and you pick the top option which is so wipe the chassis. and then restart your phone. this will clear your temporary data but does not hurt any of your actual data for the phone. I have been doing it after every update.
  2. G1572469583021
    JasonNR
    Thank you. I know that I'm not the only one with the problem, but I don't know if it's affecting everyone. Try to do a speedtest after the update and see if it changes from 5G to LTE every time.
    Also what is a Jessie partition wipe? The cache?​
    all right so far I just did the update my battery is going to take a hit for the day but that's okay it'll go right back up. posting while I'm on 5G did a speed test is working as normal as I have been. I live in the LA area and where I'm at LTE is actually pretty slow on wolf around 15 to 20 and on 5G I'm getting around 40 to 50. It is not switching to LTE while I'm doing the speed test. we'll see how it goes if we have any issues I will report it.
    to add to what I think it is I believe it is the towers being over text and other towers in your area probably aren't fully updated yet. be patient will work itself out if not they'll fix it. I'm just surprised we're getting updates monthly now when OnePlus said they do bi monthly updates. and once the Sprint merger fully closes we will get access to mid-band 5G yes these phones have the mid ban 5G for Sprint's that ban 5G.
    JasonNR likes this.
  3. JasonNR
    Cupcake Mar 30, 2020
    JasonNR , via OnePlus Community App , Mar 30, 2020 :
    Thank you for testing. I did what you told me and I'm still having the same problem. It might be the network like you said. Maybe the others having the same problems on reddit are in areas that are getting set up for the merger.
    Hopefully it gets fixed soon, with the previous update I was getting 380 down 44 up on 5G.
  4. G1572469583021
    do you live that you're getting those speedsI'm in LA and in some areas I do get a hundred but most there's something about 50. what's the merger does closing a flip on and transition Sprint towers to T-Mobile towers and switch over and turn on mid-band spectrum for T-Mobile customers are phone does have mid band things to see in order to use Sprints mid-band 5G which will have really good speeds about to even 600 megabits. I love how T-Mobile's doing there layered cake approach to 5G we have 600 megahertz band 2.5 gigahertz band and millimeter wave. unfortunately our phone only has low and mid band 5G but that's fine.
    I do think it's going to be the network area because I've got a much better coverage now as towers come online I have talked to T-Mobile engineers and it does take 28 days for one tire to be upgraded so the remaining tires in your area are going to take up the brunt cuz I have to fully shut down the tower that includes LT that's on that tower as well.
  5. JasonNR
    I live in Puerto Rico. I don't think mmWave is going to be here anytime soon, low band and mid band is enough for me until then.
  6. arrenvillasenor@ , via OnePlus Community App , May 6, 2020 :
    guys what if everybody filed a refund .
    I know we have a agreement.
    OnePlus only wants is to build a lot of model .
    even OxygenOS still developing never supported the McLaren 5g.
    OnePlus 8 . supported already? 😆😅
  7. G1572469583021
    Gingerbread May 6, 2020
    G1572469583021 , May 6, 2020 :
    I am pretty sure we are going to get the vision OS updates not even the 7t has got it yet and it's international of course they're going to cost you on their newer phone first and then update the older ones after
  8. #29
  9. G1572469583021
    Gingerbread May 11, 2020
    G1572469583021 , May 11, 2020 :
    not sure where you got that one plus is not supporting the fudge McLaren but I'm getting a lot of updates every month which comes from one plus. am I a 5G McLaren is working like a dream. I've no issues to complain about
  10. arrenvillasenor@ , via OnePlus Community App , May 12, 2020 :
    what u got?
  11. arrenvillasenor@ , via OnePlus Community App , May 12, 2020 :
    where I living bro .
    I Liv United States . come over here so you will see if working or no
  12. G1572469583021
    Gingerbread May 12, 2020
    G1572469583021 , May 12, 2020 :
    dude I also live in the United States, I had T-Mobile since I have the 5G McLaren. And again I have been getting updates for the 5G McLaren every month last update was in of April with April security update. then again I've had no issues with my phone.
  13. #34
  14. arrenvillasenor@ , via OnePlus Community App , May 13, 2020 :
    oh ok so the OnePlus 7t pro working ? even your unit is OnePlus 7t pro 5G McLaren edition ???
  15. arrenvillasenor@ , via OnePlus Community App , May 13, 2020 :
    can you find where's the 7T pro 5G McLaren edition :)
  16. G1572469583021
    Gingerbread May 13, 2020
    G1572469583021 , May 13, 2020 :
    first of all you are using a third-party oxygen OS updater which is not from OnePlus what's the weather it is even said so. also do you even see the OnePlus 7t US edition that's on T-Mobile in the oxygen updater no you do not. this is because the US versions have the same oxygen OS but they do not have the international firmware. OnePlus is the one who does the updating for T-Mobile sends it back to t to T-Mobile and T-Mobile sends it out.
    so if you're relying on a third-party oxygen OS updater that is a third party app not done by it OnePlus. That does not help your case OnePlus support the OnePlus 70 that's on T-Mobile and supports the OnePlus 70 pro 5G McLaren.
  17. #38
  18. #39
  19. SeaRefractor
    Gingerbread May 29, 2020
    #40
